interior lights and door dinger problem
Old Sep 10, 2003 | 07:57 PM
jhornback's Avatar
jhornback
i have 97 ford f150 and sometimes not all the time the lights inside stay on while your driving and when you arent driving plus the the door dinger dings and also the door ajar light stays on -. i have to pull the fuse out so i won't run my battery down.. thanks jim
Old Sep 11, 2003 | 08:48 AM
HomerWinzlow's Avatar
HomerWinzlow
You have a sticking door ajar switch on the drivers door. You can try spraying the latch down with WD40 and open and closing the door to free it up. If it doesnt work you need to replace the switch which is mounted on the bottom of the latch assembly inside the door.
jerseymike
May 5, 2016 11:10 PM
vidaliaman
Apr 5, 2016 04:22 PM
superduty4x4
16
Mar 17, 2011 04:11 PM
ReAX
Electrical Systems/Wiring
Nov 5, 2008 03:56 PM
jhutche
Aug 31, 2004 01:37 AM
