Steering pump
Old Apr 19, 2025 | 12:44 PM
Gjorgjija's Avatar
Gjorgjija
Steering pump
My pump is leaking, so I need to change it.
Any videos how to? There is plenty but for trucks, no one for van.
1994 7.3idi ambulance.
Br
Old Apr 19, 2025 | 03:29 PM
BigBlue2's Avatar
BigBlue2
Where is the leak? Some have reported using PS pump stop leak with good results.
I don't know about van PS pump removal. Is it so much different from the trucks? On the truck's I found its easier to loosen the adjuster bolt and mounting plate bolts, then remove the pivot bolt and spacer and tip the pump back on the adjuster bolt and retighten it to hold the pump tight. Remove the belts and the high pressure hose with a wrench. Remove the low pressure hose by removing the clamp. I find it easier to use a small open end wrench against the end of the low pressure hose and then pry against the wrench to push off the low pressure hose. Otherwise you can easily damage the hose end trying to pry it off with a screw driver. It's also a good idea to use a small lube pump to drain the fluid out of the pump before removing hoses to minimize fluid spills. Pump it into a clean container and reuse it if it's clean. Then remove the adjuster bolt
​​and remove the PS pump. Installation is the reverse. When the pump is installed and hoses reattached fill the pump with fluid. Prime the pump by spinning the pulley before the belts are on. Check the level, add fluid if needed, spin the pulley more, check...repeat till cold level is reached. Replace belts and tension them.
75neuharth
Jan 26, 2017 06:40 PM
Dutter
1983 - 2012 Ranger & B-Series
Aug 28, 2011 10:50 PM
33bronco
1978 - 1996 Big Bronco
Mar 17, 2003 06:55 PM
