Idle problems
Old Apr 13, 2025 | 08:02 PM
89 4.9's Avatar
89 4.9
6th Gear
Idle problems
My 89 f-150 4.9 5 speed manual is surging from 800 to 1500 rpm, what could be causing this? Iac? Throttle position sensor? I have replaced both including new harness plugs. I took off throttle body and cleaned it out with throttle body cleaner and scrubbed the bores. Also on an unrelated note, when I am driving, and I shift... It cuts out for a split second, and when the throttle is pushed more it runs fine, just shifting it driving and hitting the acceleration, it also cuts for a brief second and goes back to normal, revving the engine in neutral it also does this floor it and it cuts for just a split second then catches up and reves freely. I assume throttle position or iac, but I replaced them ,I suppose I could have bad new parts? Any theories or tests or ideas? 💡 Thanks in advance!
Old Apr 14, 2025 | 08:49 AM
FuzzFace2's Avatar
FuzzFace2
Being you have EFI and a computer I would pull codes and go from there.
But I am thinking you have a vacuum leak somewhere and it is making the IAC go bonkers and why it hunts.
Start spraying the intake and vacuum line with carb cleaner and when the RPM changes the leak is near by.
Dave ----
Willzale
May 5, 2024 04:54 PM
Junktownbill99
13
Apr 25, 2024 07:39 PM
Mountain_anderson
Oct 27, 2023 12:25 PM
john-9
Aug 1, 2021 10:49 AM
fishin machine
1978 - 1996 Big Bronco
Apr 5, 2004 03:17 AM
