72 F-250 highboy
Old Apr 11, 2025 | 09:21 AM
coloradotrk's Avatar
coloradotrk
72 F-250 highboy
Good morning
I lost all power to my cab, solenoid is working if I jump it
i’m guessing most likely fuse able link wire
any ideas where I could find a replacement, that’s if it’s the problem?
no power to the headlights, fuse panel, or dash.
thanks
Old Apr 14, 2025 | 08:07 AM
fe390pc's Avatar
fe390pc
Dennis Carpenter, CJ Pony Parts and possibly LMC for fusible links. Take a look at the ignition switch as well, there were two styles used in our trucks, one with round pin connections (not great) and one with blade connections (less issues). Look at he connector once its unplugged from the switch and inspect for heat damage indicating bad connection. Good luck.
Katoom
Apr 28, 2022 10:30 PM
tesserra
Electrical Systems/Wiring
May 19, 2020 07:54 PM
bradshaw6243
1983 - 2012 Ranger & B-Series
Jul 2, 2011 04:56 PM
doocrue
2004 - 2008 F150
Feb 20, 2006 09:24 PM
OD
Nov 23, 2002 09:12 AM
