switched power?
Old Nov 22, 2002 | 09:18 PM
OD's Avatar
OD
Post switched power?
I wanted to find a place to pull switched power to hook up a SW voltmeter and an hourmeter on a below dash panel in my '02 F350. It is a 4X4,, with powerstroke and automatic. I see a 10A fuse (29?) in the fuse panel that is called out as being for "customer accessories" in the owner's manual. Where is this connected to? Is there any other place I can get power that will go on only with the key in IGN? With the hourmeter, I don't think I'd want it to run in ACC. If it isn't fused. I could add an inline, low amp fuse. What other power sources are built in the harness that I could access? I do not want to just jump in and tap any old wire. Thanks for any help. OD
Old Nov 23, 2002 | 01:13 AM
steve83's Avatar
steve83
switched power?
You can add terminals to the empty fuse positions in the dash & engine compartment fuse blocks. I have some if you can't get any from local junkyards.
Old Nov 23, 2002 | 09:12 AM
MagBayBrian's Avatar
MagBayBrian
switched power?
