PSD headers
Old Dec 4, 2003 | 09:33 PM
HerbertKornfeld's Avatar
HerbertKornfeld
PSD headers
Why does everyone talk about modifying the exhaust system from the turbo back, but not the exhaust from the engine to the turbo?
Wouldn't that make the engine flow better and provide a HP boost?
Old Dec 4, 2003 | 10:43 PM
believer45's Avatar
believer45
A few are working on it but there are some problems about headers on a V-8 with a single turbo mounted top rear of engine in such a cramped engine compartment. I have not heard or seen anything on results.
Dave / Believer45
Old Dec 5, 2003 | 05:36 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
There are alot of issues to be worked out in doing this. For one, there is very limited space in the engine compartment. Sure, a guy can gut it out and change everything around and build him a set of headers, but then you'd need a bigger turbo, and then the heads really don't flow well, stock. And currently there are few (if any) aftermarket valves, etc. to increase flow in the heads.
It's easiest to open up the exhaust turbo-back, with substantial gains in doing that. It's coming, but may be a little while yet.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Dec 5, 2003 | 08:35 AM
believer45's Avatar
believer45
Thanks DZLJIM - I figured someone a little closer to the R&D would chime in.
Dave / Believer45
Old Dec 5, 2003 | 09:17 AM
HerbertKornfeld
DZLJIM -
If the heads don't flow well, does that mean that the PSD would respond to head work the same way that gas engines do?
Old Dec 5, 2003 | 02:03 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Well, to put it simply, every little bit helps.
But this kind of mod is just getting some attention, so there are only a handful of guys out there that can contribute. From what I am told, the PSD will not respond to headwork JUST LIKE A GASSER. The real advantage for a gasser is going to an aftermarket head with bigger ports, runners, etc. There is nothing out there yet for the PSD.
It sounds strange, but we're doing things bass ackwards with the diesel by starting at the tail pipe and working inward. On a gasser you start inside and end up at the pipe.
__________________
Old Dec 5, 2003 | 07:07 PM
Quadzilla's Avatar
Quadzilla
Mr. Rose-
I like your signature; tastefully understated.
Old Dec 5, 2003 | 09:18 PM
HerbertKornfeld
Speaking of signatures, DZLJIM, do you really have a twin turbo PSD? Did they come that way in 96 or is it custom?
Old Dec 6, 2003 | 05:26 AM
Quadzilla's Avatar
Quadzilla
In case DZLJIM doesn't resurface, I'll try to answer for him. His truck is far from stock, and he's done extensive work on developing a twin turbo set up for it. That's what I meant about his signature being tastefully understated.
Old Dec 6, 2003 | 06:21 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Thanks, Quad.
__________________
Old Dec 6, 2003 | 10:06 PM
HerbertKornfeld
Any chance DZLJIM will be reporting on his mods? Adding to his gallery perhaps?
I'd be very interested in seeing what he's done.
Old Dec 6, 2003 | 10:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Try these pics
J0244
Mar 23, 2014 10:06 PM
PrinceValium
6.7L Power Stroke Diesel
16
Nov 21, 2011 01:52 PM
kennedyford
May 13, 2007 11:04 AM
mc01svt
6.4L Power Stroke Diesel
Jul 4, 2006 10:36 AM
spitball
Jul 27, 2004 02:41 PM
