Intercooler Pipes
Old Apr 9, 2025 | 08:20 AM
  #31
powerboatr's Avatar
powerboatr
Originally Posted by Overkill2
If there was one bullet proof design, that would be it. I'm saying that because its made from solid metal pipe, and for someone working the ***** off their truck... but it's always possible for silicone boots to pop off first though..
That said, that's a lot of money for one pipe only and probably overkill for the average truck but hey, I'm all for overkill...
I don't really think there would be that much more flow then say one of the other pipes, just because it has the cobra head design at the bottom...
you reminded me of my 06. 6.0
blew a lower hose coupling off , pulling over 30 lbs towing a long cargo trailer and scooting pretty quick..it waited to blow as was passing a guy on a motorcycle
when it blew it sounded like a tire, truck shook and he disappeared
I thought oh crap I just Gatored an unsuspecting traveler
we stopped and luckily the clamps fell onto parts and I was able to get it back on...stopped at walmart..hair net sprayand alcohol for a better fix.
never blew again.
Never saw the scooter after.. I bet He had a heart attack
moral is when i check the oil, I wiggle the couplings now ..
on 6.7 lots easier to get to and see than the 6.0
the rubber cold pressure hose imo seems like a weird after thought
Old Apr 9, 2025 | 08:37 AM
  #32
Overkill2's Avatar
Overkill2
never blew again.
Yeah sounds like you had a little bit of a pucker effect, to be sure...
Mine happened after my DPK kit install when I took my truck for a test ride up the big hill by my house when climbing the hill, heard a big "POP" when the lower boot came off my Rudy's cold pipe and lost power... managed to crawl up the rest of the hill. Opened the hood and was relieved it was only that. Scared the crap outta me. Went back home, cleaned the pipe and boot real good, remembered the hairspray trick that I heard about here, used the wife's hairspray, reassembled and let sit overnight. Been good since then... July 2023..
I'll assume you're referencing Ford's decision to go with a rubber hose for the factory cold pipe?
Old Apr 9, 2025 | 09:24 AM
  #33
HRTKD's Avatar
HRTKD
I cleaned the metal flange thoroughly with carburetor cleaner on a cloth. To ease getting the pipe on the flanges I used glass cleaner, per the H&S instructions. The bottom flange took the most time. I'll take a look at checking the clamps. I tightened them to 90 in/lbs, also per the H&S instructions. But I'm about 600 miles from my torque wrench.
Old Apr 9, 2025 | 09:31 AM
  #34
Overkill2's Avatar
Overkill2
Have a safe trip.
MrQuick
Dec 27, 2021 08:13 AM
willowbilly3
1947 and Older Ford Trucks
Feb 22, 2016 09:02 AM
earthquake68
24
Mar 26, 2014 04:42 PM
gearheadstik
Mar 22, 2009 07:34 PM
