Anyone try an inline coolant filter?
Old Mar 28, 2025 | 04:54 AM
Olds64's Avatar
Olds64
That's a handy trick using a multimeter to test the health of your coolant. For those concerned with the health of their cooling system you can always run a Zinc anode in the radiator.
https://www.summitracing.com/parts/fld-fhp32004
Old Mar 28, 2025 | 07:27 AM
WCMtn1990's Avatar
WCMtn1990
I went with this, https://ve-labs.com/collections/radc...p-13lb-hexagon
Old Mar 28, 2025 | 09:58 AM
BigBlue2's Avatar
BigBlue2
Originally Posted by WCMtn1990
Can you visibly see the magnesium anode? It might be interesting to weigh the cap new and then check the weight over time? To see how effective it is?
Old Mar 28, 2025 | 10:25 AM
ihc1470's Avatar
ihc1470
Since it is the block that has issues on the 7.3 and the block is cast iron I wonder what good that cap will do. I did not see cast iron mentioned at all for things it would protect.
Old Mar 28, 2025 | 11:42 AM
Olds64's Avatar
Olds64
Using an anode protects the coolant from electrolysis. I guess magnesium is preferable to zinc. Here's a good thread, I didn't look to see if it was mentioned before on FTE or OBs.
https://www.jalopyjournal.com/forum/...anode.1271114/
Old Mar 28, 2025 | 02:48 PM
BigBlue2's Avatar
BigBlue2
Take a look at the galvanic scale. Iron is more noble than aluminum. I sispect that magnesium is higher than aluminum to protect your radiator. Zinc is up there too. But probably not enough for aluminum protection. Then there is pH which can get acidic. Regular changing of coolant solves that.
Old Mar 28, 2025 | 09:19 PM
WCMtn1990's Avatar
WCMtn1990
It's not for the block. It's to theoretically offer a sacrificial part instead of the radiator sustaining damage. All the articles I've read regarding electrolysis and coolant make reference to aluminum parts being damaged. Heater cores and radiators are usually mentioned as victims of electrolysis. More frequent coolant changes and flushes would seem to help as well.
Tom14032
May 7, 2015 09:11 PM
draboo
Aug 15, 2012 08:58 PM
paulkcbulm
Jul 22, 2011 09:21 AM
jack700
Jan 13, 2010 05:51 PM
MADVAN
May 23, 2009 02:41 PM
