TRANSMISSION MALFUNCTION
Old Mar 22, 2025 | 01:11 PM
mh_merc's Avatar
mh_merc
What would cause a 1 1/2 ton non-synchro 4-speed to pop out of fourth gear?
Old Mar 22, 2025 | 01:55 PM
85e150's Avatar
85e150
Worn shaft, worn shift fork, worn shifter. One or all.
Old Mar 22, 2025 | 05:27 PM
51504BAT's Avatar
51504BAT
Worn trans mounts?
Old Mar 27, 2025 | 01:40 PM
FireEngineMike's Avatar
FireEngineMike
My 1940 1-1/2 ton 4-speed slipped out of 3rd when I bought it. A mechanic swapped in the gearset from a spare tranny and installed new bearings, etc. to solve it. 3rd gear was bad.
Old Mar 27, 2025 | 01:52 PM
charlie g's Avatar
charlie g
FTE Community Team
worn gear and slider hub,
Old May 3, 2025 | 12:37 PM
mh_merc's Avatar
mh_merc
UPDATE: The pin that inserts through the threads for the cap on the shifter and engages into a slot on the shaft was worn so that it was tapered and too short, so the shifter was not properly held in place. A new one was made, and three new detent springs were installed - should be good for another 75 years! Huge thanks to Anthony, of Coachcraft (Fillmore, CA) who had it diagnosed over the phone and had it fixed in a few days.
Mountain_anderson
Nov 8, 2024 06:49 AM
4wheelsandahitch
Feb 23, 2022 04:51 PM
mike_black
1983 - 2012 Ranger & B-Series
Jan 7, 2016 09:04 PM
1952henry
Nov 24, 2015 05:17 PM
