Gear splitter?
Old Nov 6, 2024 | 10:19 AM
Mountain_anderson's Avatar
Mountain_anderson
Gear splitter?
Anyone put a gear splitter in their bullnose? With how much success? I know theyre expensive, is there a junkyard alternative I can steal off another truck?
Old Nov 6, 2024 | 08:00 PM
FuzzFace2's Avatar
FuzzFace2
When you say "Gear Splitter" what unit are you asking about the Advance Adapter Range Splitter over drive OR the gear Vender over drive?
The AA unit is no longer available new so that leaves only the GV over drive.
If you do a search in the older truck areas you may come across a unit called Brownie, they come in under / direct or under / direct / over or direct / over.
Like the Advance Adapter unit they are no longer made.
They say sometimes you get lucky and can find any one of the 3 in a junk yard, or one of the on line selling sites.
I got my AA new just before they stopped making them when Covid hit.
The other thing to know is the AA can only be used with a manual trans and because where it gets installed can be used in 4x4 mode.
The GV can be used with auto or manual but not in 4x4 mode as it only goes to the rear axle.
Same with the Brownie as it is a stand alone unit after the trans and I only know it to be used with manuals.
If you look at the GV unit new and then look at the ZF5 and what all is needed to install I would say they come out to about the same price when I checked years ago.
Dave ----
Old Nov 7, 2024 | 04:57 PM
Franklin2's Avatar
Franklin2
What are you trying to achieve? Overdrive? Underdrive? Trying to use a underpowered engine?
Old Nov 8, 2024 | 06:49 AM
FuzzFace2's Avatar
FuzzFace2
Arint all motors under power
I dont know of too many that want under drive unless they have a really tall rear gear with tall tires then you could just run a granny first gear transmission to get start moving.
With a 300 six, 2.75 rear gear and 235/75/15 tire, starting in 2nd with my NP435 2nd is just a little too tall for my liking when empty.
I do like the granny over drive when empty but the shift from granny to 2nd over and then 3rd direct is a little much.
So empty it is 2nd, 3rd, 3rd od, 4th, 4th od.
Pulling the trailer it is granny, 2nd, 2nd od, etc. as the trailer has some weight to it and the 300 dose not spin to high between shifts like a v8 would.
Oh my final in over drive and 2.75 is something like 1.97:1 I do have a 2.47 rear gear I could run if I wanted to get the RPM lower at a higher speed
Dave ----
4wheelsandahitch
Feb 23, 2022 04:51 PM
82_F100_300Six
Feb 17, 2017 01:40 PM
mike_black
1983 - 2012 Ranger & B-Series
Jan 7, 2016 09:04 PM
1952henry
Nov 24, 2015 05:17 PM
