M235 Diff Cover
Old Mar 21, 2025 | 08:52 PM
sundial's Avatar
sundial
1st Gear
M235 Diff Cover
First, thank you all for this great forum. I have been lurking for a while without much of substance to contribute, but now I find the need to ask a question.
My 2024 F-250 has the Dana M235 front axle. Has anyone purchased the Ford Performance differential cover that is meant for the rear axle on the Bronco Raptor and used it instead on the front axle of their F-250?
https://www.ford.com/product/ford-pe...er-p4000196871
The Ford website claims it only fits the Bronco Raptor, but I think this may be because of the three bolts that are meant to hold line connectors on the rear axle of the Bronco. I can't imagine those would cause any problems when used on the front axle of the F-250, other than just sticking out more than normal bolts. There are a few other manufacturers that I have seen making an M235 cover, but they are significantly more expensive than the Ford Performance cover. I have a Ford Performance cover on my rear Sterling 10.5 and I like it.
Also for anyone who has installed any Ford Performance cover, dumb question but which side of the gasket faces the cover and which side faces the diff? There is nothing in the instructions on this and it seemed to line up with the bolt holes either way. I installed with the green (fibrous) side facing the diff since that surface is not as smooth as the diff cover surface. I put the smooth silver surface facing "out" toward the diff cover. Seems to be doing just fine with no leaks, but have only put about 500 miles on it since installing.
TrevorK
Nov 27, 2018 06:51 PM
davran
Aerostar
Feb 13, 2018 07:15 PM
justcruzin125
Sep 17, 2015 12:51 PM
Pickupman2004
Nov 19, 2009 12:41 AM
lionsteve
17
Sep 13, 2007 11:56 AM
