Sponsored by: Real Truck
Passenger Front window issues
Old Mar 20, 2025 | 09:48 AM
jjonesprolift's Avatar
jjonesprolift
1st Gear
Hello all,
I am working on a 2015 F550 crew cab truck and am at my wits end on a power window problem. The passenger front window quit working. took the door panel off, removed the regulator and replaced it. This did not change anything. I took the new regulator back out and plugged it in while it was out of the door and when the switch is pressed for up or down, I get a faint clicking sound (both directions) but no regulator movement. I replaced both the passenger side door switch and the driver side door switch and nothing has changed. I cannot find a wiring diagram for this. Does anyone know of anything I am missing or have a diagram so I can try to trace down a wire issue. Any feedback or insight appreciated.
Old Mar 20, 2025 | 11:25 AM
ifrythings's Avatar
ifrythings
Make sure F3 30A in the BCM(interior fuse box) is good, with the key on, you should have 12v on the delay accessory wire going to pin 6 of the motor and pin 5 of your switch. With the switch pushed you should get 12v out of either of the function wires to the motor. Don’t worry about the Global Open wire.
Old Mar 20, 2025 | 12:22 PM
Mike1's Avatar
Mike1
Not big on wiring, but make sure your wires through the door looms aren't broken causing a bad connection.
burnettd01
2004 - 2008 F150
Aug 2, 2023 10:33 AM
HorsePower Junkie
Jul 27, 2021 12:18 PM
renegade_75
Jun 18, 2016 08:43 AM
projump
2004 - 2008 F150
Jul 18, 2015 07:38 PM
TYZ78F150
May 17, 2014 08:13 PM
