Crew cab power window problems
Old Jun 14, 2016 | 02:05 PM
renegade_75's Avatar
renegade_75
I have a 1995 F350 crew cab that I'm having trouble with. The windows all work from the drivers door, but the passenger side in the front, and the drivers side in the back don't work from their own switches. If I'm operating one of those windows from the drivers door and you push the switch in on one of the problem doors, the window quits moving. I don't have a book that has any wiring diagram for the window circuit. Does anybody have any experience with a problem like this? Does it sound like a wiring issue, or bad switches?
Old Jun 14, 2016 | 07:08 PM
Lead Head's Avatar
Lead Head
Power windows are tricky, in that the problem you describe could be caused by a bad driver's switch, a bad individual window switch, or a wiring problem.
This is just a generic diagram, but they're all pretty much the same. I think your best course of action will be to open up the door panel of the problem window, and get at the window switch. Two wires should go to the motor, and the other 3 should come from the truck.
With the driver's switch in "neutral", two of the wires on the passenger door switch should have direct continuity to ground, and one should have power.
Make sure you unplug the window motor before testing.
Old Jun 14, 2016 | 10:10 PM
renegade_75
I will definitely check out the switches in the problem doors, I hope it's as simple as a bad switch!
Old Jun 15, 2016 | 03:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
usually is. the switches are a known problem on these trucks.
Old Jun 16, 2016 | 08:39 PM
Diesel_Brad's Avatar
Diesel_Brad
The wire that goes from the cab to the door is the MOST COMMON PROBLEM on the crewcab doors since they bend so much, then brake
Old Jun 17, 2016 | 04:28 PM
tjc transport
i ain't rite
true Brad, but if the wire is broke the window would not work from the driver side door. since it works from the master but not the door switch, it has to be a bad door switch.
Old Jun 18, 2016 | 08:43 AM
Diesel_Brad
Sorry, but There are 5 wires that go to each door. Only 2 are used for the master window switch
FERdter
May 28, 2018 12:19 PM
Tim Hodgson
Electrical Systems/Wiring
Nov 16, 2017 08:22 PM
gabes
May 8, 2015 09:12 AM
drew213F250SD
Aug 31, 2010 08:17 PM
bgblktruk
1978 - 1996 Big Bronco
Sep 12, 2005 07:58 PM
