Checking For Correct PCM
Old Mar 19, 2025 | 10:22 AM
diggerrigger's Avatar
diggerrigger
Deleted after no response to questions
Old Mar 19, 2025 | 10:32 AM
wwhite's Avatar
wwhite
From another thread: https://www.ford-trucks.com/forums/1...l#post21407865
Your computer JAB1, hardware SMD-219, F4TF-12A650-ARB is for a MAF 302(5.0l) 4R70W California emissions I believe.
In other words, Yes, correct for your truck if built for California.
Old Mar 19, 2025 | 10:34 AM
wwhite's Avatar
wwhite
The eec tear tag/catch code/calibration sticker may be down here on the cab circled in red:
Old Mar 19, 2025 | 10:39 AM
diggerrigger
wwhite's Avatar
wwhite
Some other EECs that would work with 4R70W
BUG2 F4TF-12A650-BBC
HUG0 F4TF-12A650-APA
HUG2 F4TF-12A650-APC
Old Mar 19, 2025 | 10:50 AM
diggerrigger
So, the 4 digit sticker you referred to earlier is the tear tag?
And no. I haven't been able to locate such a sticker. I've looked everywhere including pulling the pillar trim.
Old Mar 19, 2025 | 10:53 AM
diggerrigger
@wwhite or anyone else.
In the linked thread, the original poster uses the term AODEW. Is this a generic term for AOD (including E4OD and 4R70W) series transmissions?
Old Mar 19, 2025 | 11:01 AM
diggerrigger
I can't definitively back up my claim that the truck was sold in Indiana. I did find service invoices from Ruxer Ford in Jasper, IN dated prior to previous owner purchasing the truck. I assumed it had been sold new there.
Is California truck
Old Mar 19, 2025 | 11:50 AM
wwhite's Avatar
wwhite
AOD = Automatic Over Drive, pre-electronic 1980s tech, NO electronics.
AODE = Automatic Over Drive Electronic, 1990/1991 electronic control
4R70W = basically an updated version of AODE, 4-speed Rear wheel drive, wide ratio, 1992ish and newer.
AOD different from E4OD, different from AODE/4R70W(similar).
AODEW same as 4R70W, wide ratio electronic control, naming conventions...ugh.
Old Mar 19, 2025 | 11:54 AM
rla2005's Avatar
rla2005
No, it's an incorrect term for any transmission or "series".
Old Mar 19, 2025 | 11:58 AM
wwhite's Avatar
wwhite
Take a picture of the Emissions label under the hood. That will say if it is federal California emissions or not.
I think it will show "CATALYST" or "NON-CATALYST".
Old Mar 19, 2025 | 12:53 PM
diggerrigger
Can confirm that the Emissions Label states that the vehicle conforms to California regulations
Thanks for calling that to my attention
Old Mar 21, 2025 | 11:10 AM
  #28
diggerrigger
Pulled the driver's side kick panel and found the tear tag. Now completely confident that I have the correct PCM. Thanks to all for helping me sort this.
Old Mar 21, 2025 | 03:46 PM
  #29
wwhite's Avatar
wwhite
That’s probably the tag that fell off the computer that was installed. Computers have it on the connection plug, as well as on the opposite side where the J3 port is.
do you have one computer only?
or one spare and one in the truck?
1994_Floyd-150
Jul 1, 2024 03:57 PM
Joeharrison
Jun 30, 2024 04:41 AM
Kingair90
Jun 19, 2024 08:25 PM
BillAV8R1
Nov 15, 2006 07:56 PM
