Maybe I'm blind, maybe I'm an idiot ... probably a little closer to both, but I'm looking for the computer code for my 2006 F250 5.4L on the PCM and I'm having trouble locating it. I'm attaching some pics of the engine .. if someone could point it out to me, I'd be greatly appreciative.
You should be able to call any shop that sells after market computer programmers, and they should be able to tell you where to look. I have a diesel and mine is on the drivers side behind the battery, obviously not the same.
Okay. I think I found it ... the sticker was faded and had a bar code on it with the numbers 9880 on it, and then below that in very very small letter was a code with 3 letters and a number (SVR2), which I'm assuming that's it. That's the only sticker I could find on it.
If you look to the extreme left of the red box, you can see a white sticker there, but those letters were extremely small. In fact, with my crappy vision, it took me about 10 minutes to figure out if that "R" was a "P". :-)
