Checking For Correct PCM
Old Mar 18, 2025 | 11:22 AM
diggerrigger's Avatar
diggerrigger
I have a recently acquired 1995 F150 5.0 MAF 4R70W 2WD Eddie Bauer edition truck. Previous owner had given up on diagnosing drivability problems.
He did purchase a used or refurbished PCM. I wanted to verify it is correct for the truck.
Calibration code
This is what is installed
Any insight would be appreciated.TIA
Old Mar 18, 2025 | 11:32 AM
diggerrigger
I'm thinking used. No fingerprints on a hazy patina. Brown capacitors look like new, no leaks.
Old Mar 18, 2025 | 12:10 PM
Scndsin's Avatar
Scndsin
Found this thread referencing your calibration & batch code:
https://www.ford-trucks.com/forums/1...5-0-4r70w.html
Old Mar 18, 2025 | 12:40 PM
wwhite's Avatar
wwhite
Different calibration: 4- not 5.
Old Mar 18, 2025 | 12:42 PM
wwhite's Avatar
wwhite
@diggerrigger Open your drivers door, in the inside front of door jamb, right near the wind shield pillar(like on it), look for a 4 digit sticker, what does it say?
Old Mar 18, 2025 | 12:43 PM
diggerrigger
Good read. Numbers are very slightly different but close. OP in linked thread mentions CA truck manufactured in Kansas City. My truck's VIN shows KC also. It was originally sold in Indiana.
Verified as CA emissions compliant.
I think this is date of manufacture for my PCM.
08-24-94. My truck was built 09-20-94
Old Mar 18, 2025 | 01:03 PM
diggerrigger
Don't see anything. Am I looking in the right place?
Old Mar 18, 2025 | 03:23 PM
Scndsin's Avatar
Scndsin
It's usually on the forward part of door frame between hinges, but many don't have them.
Old Mar 18, 2025 | 03:32 PM
wwhite's Avatar
wwhite
What are drivability problems?
does the computer give you any codes when you check them?
Old Mar 18, 2025 | 03:57 PM
diggerrigger
Drivability problems are for another thread.
I'll continue with the drivability problems after I am confident that I have the correct PCM and ICM.
A lot of ICM discussion here
Old Mar 18, 2025 | 06:34 PM
diggerrigger
One of my concerns about the PCM is is it for a E4OD or 4R70W? Is there a problematic difference?
I have been maintaining a 1986 truck since it was new. AOD transmission though. I'm not yet versed in these more "modern" vehicles with computer controlled shifting.
Old Mar 19, 2025 | 07:58 AM
wwhite's Avatar
wwhite
can you verify the engine and transmission is original for the truck?
if not, verifying the EEC is correct for the truck is pointless.
Old Mar 19, 2025 | 08:44 AM
diggerrigger
Yes, engine is the MAF 5.0 w/F4TE cam, engine code N. Transmission is 4R70W code U. Both original to the vehicle.
PO's father purchased the vehicle used in 1999
Old Mar 19, 2025 | 09:32 AM
manicmechanic007's Avatar
manicmechanic007
Calibration code
Your factory one would have said LPT
That is what we all (at the dealer) considered the "tear tag" or "prom" calibration
That may or may not be wrong, but EVERY processor I ever pulled out that was stock, the tear tag matched the calibration codes BIG numbers
4-R54-R10 is your calibration where "LPT" is the programmed read only memory (PROM)
Old Mar 19, 2025 | 10:14 AM
wwhite's Avatar
wwhite
Nope, that is wrong.
There is no direct mapping of information of the LPT part.
Every processor? EEC-IV? I've never seen that in MAF or SD.
