Car stalling(Fuel pump)
Despite replacing the fusible links, I found that the fuel pump still wasn’t engaging, even though the fuel pump and gas tank had been replaced earlier.
A few days ago, the truck shut down again while I was driving. I’m trying to figure out why the truck continues to shut off unexpectedly. Could this be an electrical issue, or is there something else causing the truck to stall and lose power?
To bypass this issue, I ran a direct wire from the fuel pump to the fuel pump relay. This allowed the truck to start up again, as the fuel pump would engage when the key was turned. I wired it so the fuel pump only receives 12V when the key is in the "on" position.
I don't want to keep relying on the bypass wire to start the truck. My goal is to have everything function as it should, meaning when I turn the key, the fuel pump should engage briefly, then stop, and the truck should start normally. However, right now, that’s not happening. The fuel pump doesn't engage in the normal way when I turn the key.
I’ve already replaced the switch, and I've checked all the fuses and fusible links—there's no issue there. So, what could be causing the fuel pump not to operate as it normally should when I turn the starter switch on? I want everything to work as it’s designed to without having to rely on the bypass wire.
