KOEO injector Test
Old Mar 16, 2025 | 08:09 PM
FiveOJester's Avatar
FiveOJester
KOEO injector Test
Running the KOEO (key on engine off) injector test from forscan. That’s the test that goes thru and cycles each injector individually.
Truck had been sitting for 2 days so oil temps 55-60f. Injector 5 didn’t make a sound during the 3 trials.
Fired the truck, ran a bit rough but didn’t feel down a cylinder. Let run for about a minute. Retested and #5 now sounds like the rest. All other 7 sounded about the same.
FICM volts steady 47.5-49.0.
I’m guessing stiction? Is this enough to condemn the injector?
I think the 2nd good test shows wiring etc good, definitely an injector issue.
I just replaced #8 (dead miss and contribution code) so I’m debating if I need to go ahead and replace them all preventaviely or just replace #5. 153k miles.
Ran archoil last oil change (not the current one) and it didn’t really get rid of the rough running cold. Especially sitting multiple days during the winter.
I think next step is find a mechanic with IDS to run an uncompensated power balance. Cold of course.
edit: oil is 5-40 rotella
Old Mar 16, 2025 | 08:32 PM
wpg_250's Avatar
wpg_250
0w40 T6 with a double dose of Hot Shots stiction eliminator and see if she improves after 100-200 miles. I'd also dump in a double or triple dose of Hot Shots diesel extreme injector cleaner to make sure you're getting both sides of the injectors.
Old Mar 17, 2025 | 11:52 PM
BigGreenEx's Avatar
BigGreenEx
I was fighting this issue, except all eight of mine sounded fine when testing. It was the only thing left that could be causing my rough start and idle. I big the bullet and replaced 6 of them and left the two that were only a year old. No codes being thrown. Didn’t have a contribution test done though. The new injectors fixed my problem and I feel more comfortable having 8 new injectors at 195,000 miles.
Old Mar 18, 2025 | 01:31 PM
Motohead911's Avatar
Motohead911
I would definitely try to get IDS and run the uncompensated balance test. One question, do you know your fuel pressure?
Old Mar 18, 2025 | 01:57 PM
FiveOJester
yes fuel pressure is 55-60psi. I have a sensor wired into my cts3 for continuous monitoring and alarms.
Old Mar 18, 2025 | 02:41 PM
Motohead911
Short of get your hands on IDS, it just might be worth replacing that one injector.
Old Mar 18, 2025 | 08:16 PM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
What is the most economical way to get IDS access?
invintive
Jan 28, 2017 10:35 PM
Super_21
Nov 8, 2016 09:24 AM
Fordenthusiasts
Apr 28, 2011 01:05 PM
pmbmax
Jun 21, 2009 08:00 PM
whybnormal
Jan 27, 2009 05:55 PM
