20° Base Timing???
Old Mar 18, 2025 | 03:16 PM
DaveMcLain's Avatar
DaveMcLain
It would run fine and tend to make a lot of low speed and mid range torque. That's what's strange about cams. Let's say you have two cams and run them in the engine. Both of them are ground using the same masters yet one is ground on something like 107 LSA and the other one is ground on a 114. What you would find is that the cam on the tighter lobe separation would tend to idle with less manifold vacuum and depending on the duration used it might even pick up a bit of a lope. The cam with the wider LSA would tend to idle smoother with more manifold vacuum. But when tested the cam with the narrower lobe sep would make more peak torque and have better low speed performance, just the opposite of what many people would think.
Old Mar 18, 2025 | 03:22 PM
AussieEffy's Avatar
AussieEffy
Yeah that's exactly what my truck feels like. Feels great off the mark, then kinda feels real sluggish from around 50mph or thereabouts. Thats good to know mate, thanks for your input again!
Old Mar 18, 2025 | 11:13 PM
Conanski's Avatar
Conanski
E6 heads.. how did you manage that? I thought I was the only person on the planet to put those on a 5.8. The set I had were heavily ported and still the motor fell on it's face at 4000rpm, it made great torque right from idle up though. These heads are just much too small and restrictive for this displacement, but the chamber design produces fantistic swirl, I remember how the first set of plugs had more deposits on one side vs the other. And the motor would tolerate a rediculous amount of ignition advance, just driving around it was happy with 18deg but towing I had to roll it back to 14deg or so.
Old Mar 18, 2025 | 11:29 PM
AussieEffy's Avatar
AussieEffy
I think Ford Australia raised the parts bin and used whatever was left over from you guys!
Old Mar 18, 2025 | 11:32 PM
AussieEffy's Avatar
AussieEffy
That's exactly what i see on my plugs.
Old Mar 18, 2025 | 11:33 PM
AussieEffy's Avatar
AussieEffy
And the motor would tolerate a rediculous amount of ignition advance, just driving around it was happy with 18deg but towing I had to roll it back to 14deg or so.[/QUOTE]
That's very interesting, I'll try it!
Old Mar 18, 2025 | 11:36 PM
AussieEffy's Avatar
AussieEffy
Like this?
Old Mar 19, 2025 | 04:04 PM
R&RFord's Avatar
R&RFord
Responding because my plugs were the same after I rebuilt my 351 and went with GT40 heads and am curious about why?
Old Mar 20, 2025 | 11:51 AM
baddad457's Avatar
baddad457
Which GT40 heads ? The P heads use the same plugs as the E6 heads. The plug boss extends further into the chambers on both, that's probably why the differnce in the plugs after running them,
Old Mar 20, 2025 | 12:10 PM
R&RFord's Avatar
R&RFord
3 bar GT40 heads. Deposits seemed to concentrated in one spot as in the photo the OP posted.
MontyHowie
Jan 15, 2020 05:35 AM
Jam21
Jan 23, 2012 10:44 PM
nikwave
16
Aug 1, 2011 05:52 PM
gunnabebad
Feb 14, 2004 11:01 PM
78bigunns
Aug 26, 2002 11:16 PM
