post emissions cam timing?
Old Feb 14, 2004 | 08:39 PM
gunnabebad's Avatar
gunnabebad
my ? is the changed the timing of the cam so could you move up or back a few teeth and gain any hp. if so how many teeth and which way should it go. again thanks for the help and humoring an novice.
Old Feb 14, 2004 | 11:01 PM
Ratsmoker's Avatar
Ratsmoker
No, you will need to buy a pre 72 timing set. They retarded the timing 8 degrees after 1972 and you can't adjust the stock timing set to the correct specs.
