65 352 Harmonic balancer source
Old Mar 15, 2025 | 06:06 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Hey guys, like the title says, I am looking for a local source for a harmonic balancer for my FE 352.
The original balancer in my truck came loose and shifted, making timing marks no make sense. I had a decent used one in the parts shed and put it on. But being sixty years old it didn't last a year. Now it is threatening to eat my radiator or Al least leave me beltless. This is my only working vehicle at the moment so om trying to find an aftermarket source that I cab pick up today. It's the early style with the groove for the belt on the balancer itself. Any help?
I would also. Consider a good used one if anyone in the San diego area has a spare.
Thanks, Dan. TK65
Old Mar 15, 2025 | 06:51 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The balancer is reproduced. I can't say for sure where you could pick one up today, but this gives the part number and an example of one.
Ford Part C3AZ-6312-E. Harmonic Balancer - 60-67 Pass 65-67 F-100/f350 352/390 Single Groove
Old Mar 15, 2025 | 07:05 PM
Thunderkiss1965
TA455HO, THanks brother. Put the number into the Google machine and found that Dorman makes a repro balancer, single sheve built in, for $95 in stock at my local Autozone. Open till ten with a harmonic balancer puller for rent. I'll probably do it in the parking lot just to save the drive to bring the puller back. Don't need another one have three or four at work.
part number Dorman 594-014.
Dan TK65
Old Mar 16, 2025 | 08:12 AM
buck5050's Avatar
buck5050
try summit racing, talk to a tech rep. I was able to get one for a FE 390.
Old Mar 16, 2025 | 06:15 PM
Thunderkiss1965
looks like I might have to do that. I punched in the above number into gooooooogle and it came back with the Dorman number I posted. Well I went and picked it up last night and when I got the old one off this morning and compared it to the new one the diameter of the hole in the middle was obviously way off. About a quarter inch. Do you recall the diameter of your crankshaft snout? Mine is roughly 1.375" the replacemant balancer is 1.225". Do i have a sifferent crank, or the wrong balancer?
Old Mar 16, 2025 | 06:32 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Sounds like the Dorman is the wrong part. The one at CG Ford Parts that I linked to - in the More Info section shows it's 1-3/8" which is 1.375".
Old Mar 16, 2025 | 07:58 PM
Thunderkiss1965
yeah... I put that number into Google and I got that Dorman part number and got.m excited and went and bought it without even confirming the application. I was just happy to find what I thought I needed. Found one on summit for $50 more. So now my focus todsy has shifter from fixing the truck so I can get to work tomorrow to fixing the BMW so I can get to work tomorrow. And fix other people's cars.
buck5050's Avatar
buck5050
My part number ar summit is PBB- PB1111N , I dont have it , sent itto the engine builder so I cant verify the size.
jsfrenchfl
May 26, 2016 12:01 PM
67F250RET
Sep 10, 2012 06:55 PM
musicmanbiker
Feb 28, 2012 08:34 AM
Dirt Boy
Feb 17, 2007 09:51 PM
Ds7776
May 6, 2003 02:29 PM
