Harmonic Balancer???
(sigh) Your friend is unaware and so...you're now confused. All 1958/76 FE engines came with harmonic balancers. Some people are unaware, because they don't know how they're assembled.*This is the exact same harmonic balancer that my purchased new '65 F100 352 came with: C3AZ-6312-E = 1965/67 F100/350 352 / 1963/67 Ford/Merc 352/390 Passenger Cars.
The balancer attaches to the nose of the crankshaft with (1) 355721-S .. 5/8" -18 x 1 1/2" hex head bolt.
Behind the balancer is the crankshaft spacer: B8AZ-6359-A which is retained in place on the crank by the 358963-S .. 1/4" x 3/4" keyway.
* At the factory, a rubber gasket is placed between the inner balancer and outer single sheave (groove) pulley. Then the 3 parts are pressed together forming a one piece assembly.
Ford offered one, two and three sheave accessory outer pulleys that bolted to the balancer to add P/S and/or A/C and/or dual belt alternator.
4th pic in post 3: See the 3 bolts? These attach the single sheave accessory outer pulley to the balancer. If this pulley was absent, all you would see is 3 threaded holes and the head of the bolt that retains the balancer to the crank.
1st pic in post 3 shows the timing pointer.
It's so great that people are willing to provide information and opinions on this site, I've been reading many of these ever since I purchased the truck and found the information so helpful.
I guess my question now is should I take Swann79's advise and not worry about adding an external balancer
if the engine is smooth or just add it because I'm already working on the engine?
What in the heck are you talking about? Your truck already has a balancer, look at all the pics of it you posted. That's it. Some people assume it's just a pulley, but it also contains the balancer on the backside of it.> > At the factory, a rubber gasket is placed between the inner balancer and outer single sheeve pulley, then the three parts are pressed together forming a ONE PIECE ASSEMBLY! < <
Your balancer has an accessory single sheave outer pulley bolted to it, SOP at FoMoCo when adding P/S or A/C or dual belt alternator.
Apparently I'm not very good at reading either
but now I see what you were saying. Great info and thank you for your patience with my naivety. Working on this truck has been fun and challenging to say the least and having your info is truly appreciated, you rock
Thank you, cheers
Working on this truck has been fun and challenging to say the least and having your info is truly appreciated.
Here's some more info you may not be aware of inre to 1967's. 1967/72's look the same, but looks can be deceiving. 1967's contain parts that are 1967 ONLY!
1967: You push the inside handles forward to lock the doors. 1968/72's have door lock *****.
1967 only: Door shells, door lock remote controls, window regulators, door latches, inside window and door handles, arm rests, vent frames and handles, link rods for the door lock cylinders.
Same 1967/72: Upper/lower hinges, weatherstrips, glass, division bars between the vent frame and door glass, outside door handles, door lock cylinders.
More 1967 only: Grilles, dash, radio, heater and ash tray, firewall, brake and clutch pedals, bracket they suspend from under the dash. Master cylinders, power brake boosters, prop valves, low brake fluid warning light switch.
1967 hood side emblems are plain, do not contain the yellow reflectors that 1968/72's do. And there's more 1967 only parts, this list is all that I can recall at the moment.
If you ever need any of these 1967 only parts, where will you find them? Ask the big dummy.
Locating obsolete parts is the major thing I do here on FTE.Where in CA do you live?
The truck was in pretty good shape when I purchased it minus the fact the the shifter had been ripped out of the column at some point. The guy before me actually stubbed a rod through the floor for the shifter... good stuff. At some point I want to correct this by either converting to a floor shifter or repairing the column. The good news is the mickey mouse fix works and I haven't had any issues...knock on wood. I had a mechanic who owns a 69 Camper explain to me that I have a Cruise o matic tranny and that the basic floor shifter kits wouldn't work. I figure when the tranny needs work I'll deal with the shifter.
Why go 1000's of miles east to buy parts and then pay shipping charges, when Blue Oval Truck Parts (Anaheim) and the Truck and Car Shop (Orange) are located minutes away?
I had a mechanic who owns a 69 Camper explain to me that I have an MX Cruise-O-Matic tranny and that the basic floor shifter kits wouldn't work. I figure when the tranny needs work I'll deal with the shifter.
Now the shift lever flops around because the collar is no longer connected to the shift tube.
The good news is, the shift collar is available from Ford.
It's feeding time here in Hacienda Heights for our 5 Basset Hounds, will be back later with the shift collar info.
btw: Have you visited the newest attraction in the South Bay yet? Battleship USS Iowa (BB-61) located at berth 87 next to the cruise ship terminal in San Pedro.
When I'm not here on FTE, I'm there, docent tour guide.
