trailer plug no power
Old Mar 9, 2025 | 10:13 PM
tiredmec's Avatar
tiredmec
Well I replaced the trailer plug two years ago. Every thing worked till last fall. I tested the new one today it has continuity on both ends. Repaired the ground wire cleaned and replaced terminal. Don't have power at the plug. So I pulled down the next connector looks clean no green. Going to back pin the terminals see where the wires are broke. Anyone have had this problem IE pinch point or rub locations? I have Mitchell repair but cant find connector or pin outs. The tail lights work fine on truck. Just not sure where the wires run from other than front of truck.
Old Mar 9, 2025 | 11:06 PM
steve(ill)'s Avatar
steve(ill)
you dont have 12v power to charge the battery on trailer... or you dont have power to the trailer lights and brakes ?
trailer lights and brake are not tied to the truck lights and brake wires.... seperate fuse and wire..
Old Mar 10, 2025 | 09:08 AM
tiredmec's Avatar
tiredmec
There is no power to any terminal, t/s, tail, 12volt the only thing that shows its working is the ground. Now that I replaced terminal above spare tire. I relocated where it attached. Moved connector under cross member. So I don't have to mess with spare again. Took me two hours to get spare out. I mounted it back on upside down so I can check air in it. Going to test all pins for continuity in plug see if the wires are grounded in around a hour. Have 245000 miles on truck now.
Old Mar 10, 2025 | 06:19 PM
HomerWinzlow's Avatar
HomerWinzlow
Those 7 pin connectors are notorious for failing internally.
Old Mar 11, 2025 | 01:19 PM
tiredmec's Avatar
tiredmec
Well got it fixed. Had to replace about 3 foot of wire by the spare tire wire was black inside. First I tried replacing ground but could only get 6 volts out of wire. No more connector in harness now.
River
2009 - 2014 F150
17
Dec 20, 2015 09:33 PM
kevsimons
All Things Towing
33
Nov 15, 2013 04:27 PM
Aftrmidnite
Aerostar
Dec 6, 2004 03:57 PM
Frank Lang
All Things Towing
Feb 11, 2004 09:17 AM
tsheriff
Apr 23, 2003 05:44 PM
