E4OD Intermittent Shift/ TC Lock Issues
EDIT: The solenoid pack connector had trans fluid inside.
Post moved from Misc.> Transmission
Code Scanned
Torque Converter/ No obvious bluing
Bottom of Pan Fluid
Oil Drained from T/C
Towel sample of T/C Oil
Check trailer connector for shorted wires.
Reset TPS by doing KOEO press gas pedal to WOT and release turn key to the off position and do this step 2 more times. Sometimes the PCM does some wonkie stuff with shifting and reseting the APS gets it back to normal.
The trailer connector was replaced last fall and wires were cleaned up, previous owner did have a topper that was wired into the clearance/ park light circuit, and I plug into those for the clearance lamps on my sled deck. The issue happened when clearance lights were off. Have not ran it much in the dark.
I did do a TPS voltage test with the scanner, images attached, but have not reset the TPS.
Idle
WOT
