Missing Vacuum line
Old Mar 4, 2025 | 06:15 PM
Tones023's Avatar
Tones023
5th Gear
Missing Vacuum line
Recently bought my truck 96 f250 7.5 need help locating where this missing piece connects too
Old Mar 5, 2025 | 01:17 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Is the vacuum diagram still there? That will tell you where it goes.
Old Mar 5, 2025 | 09:00 AM
manicmechanic007's Avatar
manicmechanic007
A lot of those "dead head" right there at the vacuum reservoir if you do not have all the accessories that use the vacuum
Old Mar 5, 2025 | 09:49 AM
rla2005's Avatar
rla2005
I have never seen the upper and lower vacuum reservoirs tied together like that before. But, I found a VECI label for a 1997 F250/350 with a 7.5L engine:
The label shows tee.
You have two choices for where the output of each goes. One is for the EGR valve. The other is the AIRB/AIRD valve for the air injection system. Trace out the vacuum circuit that appears to be intact. The open port on the lower chamber needs to be connected or capped off.
Disregard the vacuum line and EVAP canister reference in the diagram. Your truck appears to be OBD-II that uses the newer style Vapor Management Valve.
Old Mar 5, 2025 | 06:02 PM
Bruce51's Avatar
Bruce51
The missing vacuum line runs to the purge solenoid that is in your picture top center on the firewall. It plugs into the bottom outlet. The solenoid has a round top with PA66 GF33 T8 on the top
Bruce
Old Mar 5, 2025 | 06:33 PM
Bruce51's Avatar
Bruce51
White vacuum line to bottom of solenoid.
Old Mar 6, 2025 | 07:31 PM
AuroraGirl's Avatar
AuroraGirl
maybe the t is for the source
Old Mar 10, 2025 | 06:19 PM
Tones023's Avatar
Tones023
5th Gear
thank you!
[img alt="Does it aslo connect to my vacuum tree?
When i bought my truck some of my vacuum lines were missinf ag well as my vapor line to my charcoal canister
"]https://cimg7.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/20250304_171729_80870c30dae7796dfc7edb7b61300b9f3c 61202a.jpg[/img]
Does it aslo connect to my vacuum tree? When i bought my truck some of my vacuum lines were missinf ag well as my vapor line to my charcoal canister
Old Mar 11, 2025 | 11:56 AM
Tones023's Avatar
Tones023
5th Gear
Missing charcoal canister line
Does any one have an image where this missinf line connects too? I think its my vapor like that goes to my fuel tank but i cant seem to find where it goes to the gas tank
Old Mar 11, 2025 | 01:34 PM
Bruce51's Avatar
Bruce51
Hello again hope I can help. My 97 F350 canister is capped at that outlet.. I do believe you are correct that the second line goes to the tank somewhere. Possibly top of the fuel pump/gas tank. Hard to see for sure.
If you need more vacuum line information just ask but be specific so I might provide photos if needed.
Bruce
Old Mar 11, 2025 | 02:52 PM
Bruce51's Avatar
Bruce51
Does it aslo connect to my vacuum tree?When i bought my truck some of my vacuum lines were missinf ag well as my vapor line to my charcoal canister
White line only goes to the reservoir. There is a red line from the vacuum tree on top of the engine going back to the check valve on the right side. One black line from the reservoir top goes to the tee. One goes all the way to the back left to the rear of the EGR solenoid. A small vac line goes off the left side of the tee to the fuel pressure regulator. If I miss identify parts let me know. There's more just depends on what you need to know.
Old Mar 11, 2025 | 10:02 PM
AuroraGirl's Avatar
AuroraGirl
i think it either goes to another canister or it goes to the Vapor management valve on the firewall
Old Mar 11, 2025 | 10:25 PM
AuroraGirl's Avatar
AuroraGirl
You would appear to be missing your bottom canister
Bryantkalagian
Jan 17, 2025 03:42 PM
mcassett
Sep 15, 2023 03:19 PM
BryanDowdy
Jul 11, 2023 12:17 PM
beluga3858
Dec 15, 2020 07:57 PM
thefew
Jul 23, 2020 03:56 PM
