7.3 prolonged start
Old Feb 28, 2025 | 02:27 PM
Ol’ Smokey's Avatar
Ol’ Smokey
6th Gear
7.3 prolonged start
I have a 1996 7.3 and the last couple days I’ve been having starting issues. The engine turns over normally but just won’t catch and start. I’ll turn the key off and wait then try again and it will start. It doesn’t seem to have anything to do with engine temp as it’s happened dead cold and hot. It’s seems to start easier if I cycle through the glow plugs a few times (but like I said it happens hot or cold). Anyone had similar issues?
Old Feb 28, 2025 | 02:37 PM
knottyrope's Avatar
knottyrope
remove the UVCH connectors and ohm out the outer pins to ground. Should be 1 ohm
Does oil pressure come up fast on dash guage?
What is cranking RPM, needs 200
Have a scanner? Might need to see HPOP pressures.
Old Mar 4, 2025 | 11:56 AM
Hit Man X's Avatar
Hit Man X
These keep on glowing when the lamp is out, engine off and cold starts. Even my old MB Diesel does when the lamp is out.
You may also have a POS starter combined with janky cables
Can you post any clip of it cranking? A weak starter is audible
7.3 powerstroke3456
Jan 1, 2022 11:29 AM
7.3 powerstroke3456
Nov 22, 2021 03:15 PM
ccoppens
Jan 11, 2014 01:36 AM
TAZ01
Jun 25, 2013 11:54 PM
Km1210
Nov 17, 2011 10:35 AM
