code# p1299?
Old Feb 22, 2025 | 04:03 PM
marcmy's Avatar
marcmy
1st Gear
code# p1299?
2007 explorer, 4.6v8,4x4, 175000 miles just threw a code #1299, cylinder head temperature switch? anyone have advice about what this means? cant find anything out about it. thanks for your help! just joined today and hope it comes in handy.
Old Feb 22, 2025 | 06:31 PM
shorod's Avatar
shorod
Welcome to the forum!
Did the engine go into Limp mode when the check engine light came on? That code can relate to the cylinder head temperature sensor identifying that the head temperature is too high. This will usually cause the PCM to go into heat pump mode, shutting off a few cylinders to instead pump air to help cool the engine. Did you happen to notice if the engine temperature gauge was reading normal or higher than normal at the time?
-Rod
crazymut
Mar 22, 2019 10:50 AM
scarty111
Aug 16, 2013 06:55 PM
Dozeman
Apr 21, 2013 06:29 AM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
shorthair
May 3, 2005 09:30 AM
