03 air test
Old Feb 17, 2025 | 06:06 PM
RemingtonCG's Avatar
RemingtonCG
03 air test
I’ve been having a pretty serious no start problem and lack of power, when I got the truck I went ahead and put a new hpop in it (cnc fab) and was fine for over a year. So this last week I pulled it apart and did the air test. I went through the Ipr first and with 130 psi and leaving it hooked up for 15 minutes I didn’t hear anything, then I pulled the driver side valve cover and hooked up to the port on the oil rail and after a few seconds had air under the hpop cover. Is this normal or is that my leak. Sorry if this is a stupid question just want to be sure before I do anything I don’t need to do.
Old Feb 17, 2025 | 06:15 PM
bismic's Avatar
bismic
Sounds like the IPR is leaking, or maybe you didn't command it closed .............
Nixoninc
Apr 11, 2021 04:00 PM
F0rdF0rever
Feb 8, 2019 03:13 PM
Jgard00489
Jul 3, 2016 02:19 PM
fixxxer-upper
Feb 15, 2013 11:17 PM
cdev
Jan 18, 2013 06:52 PM
