Sponsored by: Real Truck
Brake line replacement
Old Feb 17, 2025 | 09:39 AM
Headviking's Avatar
Headviking
Last Friday after my truck sat without use for a month, I decided to take it for a run. Did some errands and on my last stop I came back to the truck and when I pressed on my brake pedal I felt a pop. The pedal went down to the floor. Got out of my truck and looked under all wheels and found my left rear side soaked with brake fluid on the ground and on my fuel tank. Had it towed back home and now I need to fix it. I heard people using braided brake lines to replace old lines. Can anyone here confirm this can be done on these trucks? Considering the length of them?
Thanks for any advice in advance. I'm in Canada and it's cold and lots of snow so replacing will be a pain.
John
Old Feb 17, 2025 | 10:38 AM
Eman85's Avatar
Eman85
So this is a hard line that rusted out? I use NiCop pre-made lines very easy to work with. If needed I'll cut and flare to make them fit. Never used any braided line to replace hard lines.
Old Feb 17, 2025 | 04:38 PM
Headviking's Avatar
Headviking
Thanks for the imput.
I dont have tools to flar the lines so I may have to remove the old and replace with new fitted hard line. I was possibly looking at an easy way out I quess.
John
Old Feb 18, 2025 | 07:55 AM
Creston's Avatar
Creston
I use nickel copper at the shop. 25 ft roll comes with fittings for 25 bucks or so online. Get a harbor freight flare tool for 20 and u be fine. I have a bench flare tool and it's pretty much useless. I have an inline that is easier on your hand than the cheap ones but it's pretty big. I tend to end up using the cheap one under the vehicle about 1/3 of the time and I replace brake lines on 20-30 vehicles a year. Road salt kills them
expect issues though. If your brake line rotted then it may not turn at the hose. Then the bleeders probably aren't going to work. Here in the road salt country it's just how it goes
Old Feb 18, 2025 | 08:34 AM
JJF20's Avatar
JJF20
I agree with the Nicopp. Easy to work with. Canadian tire, Parts source, Napa, etc usually have various lengths already flared, with fittings etc. you might get away with replacing one. Or buy a roll, fittings and flaring tools. Any of the above places will have the flaring tools, or Princess Auto (Cdn equivalent to Harbor Freight) will have all the tools you need for that, flaring, line wrenches, etc etc.
More than likely the rest of the lines aren't far behind, and the hoses too.
You can look into InlineTube for a set of stainless hard lines, pre bent ready to go. New hoses all around as well.
Not fun in a snow bank.
Old Feb 19, 2025 | 02:16 PM
Headviking's Avatar
Headviking
Thanks to you all. Creston, JJF20 for your advice. And yest its not going to be fun in this weather. I just may have to wait till some snow a temps let up to work on them. I will be replacing all the lines though. I will have to do some homework on the routing location and mating areas for them. This would be my first truck brake line replacements.
Thanks
John
Old Feb 25, 2025 | 04:53 PM
Headviking's Avatar
Headviking
If and only if I was to install my own brake lines from fron front to rear. What size of brake line tube should I be looking at? Canadian Tire sells 3/16", 1/4", 3/8", 5/15".
Thanks
John
Old Feb 25, 2025 | 06:52 PM
Creston's Avatar
Creston
3/16 usually. 1/4 is usually on chevy but on some Ford too. Why idk. But I just Take a 3/16 wrench and a 1/4 inch wrench and see which one just barely fits on your brake line. I put whatever they had on them. Don't know that it matters
Old Feb 26, 2025 | 05:10 AM
Foostmoose's Avatar
Foostmoose
4wd Low
Thanks
John
I've bought a roll of copper nickel and made my own lines and I've also bought the pre formed fitted lines. Although the latter is more expensive it's much easier.
Old Feb 26, 2025 | 06:41 AM
Creston's Avatar
Creston
Not always. You have to drop the fuel tank and several other things if you want to use pre bent on a lot of trucks/suv. Then on some cars you have to go up into the car and then back under the car through the body in the back seat. If you use a roll you just send it through with tape or a cap on it and bend after. I never do pre- bent anymore at the shop unless it's big transmission line and even then I'll bend my own sometimes.
Old Feb 26, 2025 | 06:43 AM
Foostmoose's Avatar
Foostmoose
4wd Low
True
Old Mar 3, 2025 | 08:01 AM
lshort's Avatar
lshort
as stated copper nickel is the only way to go, as far as dropping the fuel tank, that would be the best way but I think it can be done without dropping it, just leave the old line behind the tank and fish the new one behind the tank
TheCoach
Mar 13, 2019 01:18 PM
rexblue
Nov 1, 2018 05:26 PM
artfd
1997 - 2003 F150
May 16, 2015 08:11 AM
quisp-n-quake
Oct 26, 2007 11:07 AM
Bowstring
Apr 8, 2007 11:18 AM
