4R100….rebuild AGAIN or replace….
Old Feb 13, 2025 | 02:49 PM
SPS573's Avatar
SPS573
Well…..here we are again. Seems like my 4R100 bit the dust again. (6.8 V10 4x4) Has been rebuilt 3 time in the last 3 years! Yes I know, apparently the person rebuilding it didn’t do a good job. Should have gone to BTS but needed truck asap at the time. Meh.
So now I’m thinking what else I can do. I was thinking about a 10R80. Not sure how hard it would be yet but did find out US Shift has a stand alone controller for it so that should work. Also, it seems like the 10R80s have a lot of issues as well?
That brought me to thinking of a ZF6 manual swap. Not sure if I want to go that route yet.
Any advice? Stop thinking so hard and just keep the 4R100? Thanks.
Old Feb 13, 2025 | 02:56 PM
charlie g's Avatar
charlie g
FTE Community Team
your correct he's not doing something right that a normally stut trans,
swapping is going to lead to PCM wiring and dash issues issues .just find a better shop or go that bts route
Old Feb 13, 2025 | 03:41 PM
Antonm23's Avatar
Antonm23
Either the dude really sucks at rebuilding transmissions ,,,, or maybe your use (possible abuse) is just more than the trans can take.
Considering your screen name and the pic in your avatar, I'm guessing that maybe you play with the truck a little offroad. If that's the case , then you might just be killing the transmissions with heat. Spinning tires and 4x4 low range puts a ton of heat in the transmissions fluid because the torque converter never locks.
Whatever new trans you go with, I'd suggest an upgraded trans cooler and a trans temp gauge be on the list of things to buy.
Old Feb 13, 2025 | 04:00 PM
EngineeredEats's Avatar
EngineeredEats
Trailering
Is a 10R80 swap even possible? Do the bell housings match up?
Old Feb 13, 2025 | 04:09 PM
Antonm23's Avatar
Antonm23
With enough money ,,,, anything is possible.
Adapter plates are just big hunks of metal (usually aluminum, but some are steel). Might have to get an adapter plate custom made for this particular application, but with the rise and general availability of CNC machines, more and more places now have the ability to make such adapter plates. You see this stuff all time in the hot-rod world where people are adapting their favorite engine into some random car, or putting a different brand transmission behind the engine they already have.
Old Feb 13, 2025 | 05:39 PM
01__Excursion's Avatar
01__Excursion
So what exactly bit the dust? Can you not get away with a rebuild, and a BTS converter only?
Old Feb 13, 2025 | 07:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When the trans was rebuilt were the two trans coolers reused or replaced? If they were reused, that's the cause of the failures. There is NO WAY to flush these trans coolers clean enough to prevent them from destroying a new transmission.
If you manage to get some other transmission in there and reuse these coolers expect that trans to fail, too.
Old Feb 14, 2025 | 05:07 AM
charlie g's Avatar
charlie g
FTE Community Team
that plus the possibility of hurting it off roading,
Old Feb 14, 2025 | 09:24 AM
EngineeredEats
Trailering
Super interesting. A 10-speed behind a 7.3 would be awesome. Not withstanding money, I assume the biggest issue would be getting the PCM to interface correctly? Has anyone on this forum ever done this succesfully?
Old Feb 14, 2025 | 12:36 PM
SPS573's Avatar
SPS573
LOL, yes I see that with my screen name. Actually this truck has never seen mud. Screen name was for my old Ranger when I lived in FL. I’m in NV now so only thing the truck has seen is light desert trails. I actually have a Mishimoto radiator and cooler in garage ready to go in. Temp gauge on list.
Not sure yet. Just got a big clunk and reved up like in neutral. Lucky I was close to my house and she very slowly limped back. I am hearing a noise from bellhousing area. So hoping maybe just a flex plate or converter? A few months back she would bog down and sometimes turn off when I put her in reverse….dunno.
You can get only the converter from BTS?? Hmmm I’ll have to look into that as well just in case. Thanks.
TWO trans coolers? Thought there was only one. No they did not replace the front one by radiator. They said it was “fine”…..pfft.
Dunno if it’s been done, toying with the idea to try. US Shift is coming out with a controller for it. But the more I research it, seems like it might not be reliable for our weight? Not sure yet….
Old Feb 14, 2025 | 06:55 PM
WE3ZS's Avatar
WE3ZS
Two trans coolers, a fluid to water cooling loop inside the radiator (some very early 7.3 rigs didn’t have this loop) and then the fluid to air cooler up in front of the radiator.
Old Feb 14, 2025 | 08:51 PM
SPS573's Avatar
SPS573
Ah! Yes. I have seen the inside radiator bypassed when upgraded to the 6.0 cooler. Is that not the correct way to do it? Should you keep both even with the 6.0 cooler?
Old Feb 14, 2025 | 09:26 PM
WE3ZS's Avatar
WE3ZS
Yes, absolutely keep the radiator loop when swapping up to the 6.0 trans cooler. I’ve run this setup on my V-10 tow rig EX for several years and many, many heavy towing miles.
That radiator loop does a whole bunch of ATF cooling!
Old Feb 14, 2025 | 09:56 PM
SPS573's Avatar
SPS573
So if it can’t be cleaned out then radiator needs to be replaced with tranny?
Old Feb 15, 2025 | 01:44 AM
Antonm23's Avatar
Antonm23
There may or may not be a benefit to keeping the in-radiator portion of the trans cooler when upgrading to the 6.0 style external trans cooler.
Personally if I were running a v10 / 4r100, I’d bypass the in-radiator cooler when putting on the monster 6.0 trans cooler. I can’t imagine the BTU capacity of the huge 6.0 cooler not being significantly larger by itself than the stock in-radiator and tiny external trans coolers the gassers / 7.3L diesel got.
