Remote start w/ camper connect
Old Feb 12, 2025 | 05:11 PM
Gregalb's Avatar
Gregalb
4wd High
Has anyone figured out, yet, how to get your slide-in camper to start charging the house batteries on remote start (i.e. and without depressing the brake pedal)?
I've searched the forums to no avail.. so I'm thinking its still not possible.
Thanks.
Old Feb 12, 2025 | 05:51 PM
OBS460's Avatar
OBS460
My DC to DC charger has an Anderson connection directly from the passenger battery so as soon as I start it and my trigger wire senses 12v it starts charging.
Old Feb 13, 2025 | 09:00 AM
Ryanc3055's Avatar
Ryanc3055
Hate to hijack this tread but do you worry about how much more wear and tear is Being put on the alternator?
Old Feb 13, 2025 | 11:09 AM
OBS460's Avatar
OBS460
No. It's only a 40amp DC to DC charger. If the dual alternators can't handle a 40amp additional load then something is wrong. I also don't have the camper living on the truck and the charger is pretty smart so it has bulk charge, float charge and then maintain so it only demands 40amps if the batteries are below 80%. Above 80% it float charges probably about half the amps or less somost of the time it isn't demanding the full 40amps. My batteries can handle 200amp charge input but between 800w of solar and the DC to DC charger it can do 412AH from dead in just a couple hours with a small load on the batteries.
Old Feb 13, 2025 | 11:11 AM
99powerstrokedF250's Avatar
99powerstrokedF250
No because these are bigger alternators than what was used in years past, when anything connected to the 12V and ground pin in the trailer plug would start charging as soon as the vehicle started. Those used to only have 100-125 amp alternators, now we're getting some that are as big as 250 amps,and multiples getting you up to 410 amps on the 6.7. There's not enough extra wear and tear being put on the alternator to worry about.
Old Feb 13, 2025 | 01:22 PM
KCoulter's Avatar
KCoulter
Are you trying to charge thru the 7-way connection?
This shows how to make the 12v pin on the 7-way hot without having to hit the brake peddle.
See page 4 of the instruction.
https://www.putco.com/wp-content/uploads/92009I.pdf
(Note: I have not tried this myself, but saved these instructions for if/when I get a chance)
ArtsBest
2009 - 2014 F150
24
May 27, 2025 01:38 AM
RandyinTN
2023+ Super Duty
Dec 11, 2024 10:58 AM
BudgetRacing
Sep 12, 2022 12:52 PM
Jefff H
Jan 25, 2020 10:04 AM
