Steering Wander?
Old Apr 12, 2025 | 01:01 PM
  #31
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by JoshHefnerX
Unfortunately there's not a good rebuilt steering box from the parts store of any kind. Yes that's a big statement and I'll stand by it. The only good reman boxes I've had were from specialty shops.
I'll stand by you with that statement too.
Old Apr 22, 2025 | 08:32 AM
  #32
z31freakify's Avatar
z31freakify
Looks like I might have found the problem, after having the old lady jerk the steering wheel around, looks like the tie rod that bolts to the pitman arm has little play, and I mean little play, I could couldn't get it to move with some big *** pliers. There's little moment, the thing that caught my attention was while holding the tie rod I felt a clack when turning either way.
Getting a new tie rod today under warranty.
Now I do believe the wife might of hit something but wont tell sor maybe the tie rod was a POS
Old Apr 22, 2025 | 11:45 AM
  #33
da-bees's Avatar
da-bees
I wouldn't either unless you want to lose your "steering wheel jerker".
Old Apr 22, 2025 | 12:15 PM
  #34
udsuth78's Avatar
udsuth78
The next question is why didn't the alignment shop catch it?
Old Apr 24, 2025 | 08:27 AM
  #35
z31freakify
No clue, maybe they use the plier technique which I personally did and there was no play, only when I had someone move the steering wheel around is when I found the tiny slop.
Old Apr 24, 2025 | 08:30 AM
  #36
z31freakify
I wont ask again don't want to loose that jerker either
Old Apr 24, 2025 | 08:31 AM
  #37
z31freakify
So I installed the tie rod yesterday, and we'll steering is way better but still have some wander, I'm rotating tires today and see what happens.
Old Apr 24, 2025 | 09:30 AM
  #38
Kwikkordead's Avatar
Kwikkordead
Things replaced in the last year
-upper and lower ball joints (Duralast Gold
-all tie rods (Duralast)
-new track bar (FoMoCo)
-new sway bar bushings and end links
-reman steering box (replaced it under warranty just last week thinking that was the problem but no dice)
-new axel shafts and seals
-new locking hubs
How about the idler arm bushing?
Old Apr 24, 2025 | 09:36 AM
  #39
FordTruckNoob's Avatar
FordTruckNoob
OBS trucks have an idler arm?
Old Apr 24, 2025 | 09:46 AM
  #40
z31freakify
No idlers arms in a 00 or a 2wd obs
Old Apr 24, 2025 | 09:59 AM
  #41
Kwikkordead
OH, it's 2wd.
Old Jun 21, 2025 | 10:09 PM
  #42
z31freakify
Finally got back at checking the truck.
After hours of moving steering around from lock to lock, removing one outer tie rod at a time and turning the wheel side to side and still feeling a drag, removing both outer tie rods and turning bo more drag, hmmm.
Moved driver side tire from lock to lock and theres zero binding, same thing on passenger side I can easily turn the wheels with my stinky pinky, it only happened with either tie rod was connected, which is freaking weird, never have I encounter something like this. I removed the steering damper to rule it out again, same thing.
After going thru my scrap pile I found the old tie rod's (the one one that connects both knuckles, installed it and same thing. At this point I'm just throwing **** to see what sticks to no avail.
At the end out of frustration and being heat soaked from the heat, i bit the bullet and took out the ball joints, warranty them out, install them, and put everything back together. After a shower, some food and quick rest took her for a test drive and what do you know the ball joints actually worked, how and why but it worked.
Now someone enlighten me why was it that I could easily turn the wheels with out the tie rods connected but was hard to turn with the tie rods attached even with the dam steering wheel? Makes zero sense but hey there's always something nrw to learn.
Old Jun 21, 2025 | 10:24 PM
  #43
JoshHefnerX's Avatar
JoshHefnerX
Something binding when under load?
Old Jun 22, 2025 | 07:25 AM
  #44
Kwikkordead
When I replaced the ball joints on my truck, it eliminated steering wander that I didn't even know was there. Test drive felt like I was driving a sports car compared to what it was doing before.
Old Jun 22, 2025 | 09:38 AM
  #45
FordTruckNoob
my stinky pinky
