Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
B600
Old Feb 8, 2025 | 07:18 PM
FormalDragon's Avatar
FormalDragon
B600
Looking for help decoding this vin# B60CLE77710.
Old Feb 8, 2025 | 07:35 PM
85e150's Avatar
85e150
Welcome to FTE.
I moved you here as your bus has more in common with the F600 trucks than the pickups.
B60 = B600 gas
C = 330 2V MD FT gas V8
L = Michigan Truck Plant
E77710 = 1969 numerical series, February 1969 production
156 = 156 inch wheelbase
G = Chrome Yellow
B600 = B600 gas, 19,500 lbs GVWR
84 = Bus Chassis (described as "cowl model" in other years)
A = New Process model 435 four speed transmission
64 = Rockwell model F-106 single speed rear axle, 15,000 lbs capacity, 6.80 ratio
No front axle code--for MY '64-'69 only optional axles were listed. So figure Ford 4,500 or 5,000 lb capacity front axle without power steering
19500 = 19,500 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
650441
65 = Oklahoma City District Sales Office
0441 = Special Order Number
If the entire warranty plate is still there, it will have more info. Should be on the firewall/cowl area. EDIT see above and below....
Old Feb 8, 2025 | 08:34 PM
FormalDragon
I'm trying to figure out what carb so I can get a rebuild kit. Also any suggestions on where to aquire a kit?
Old Feb 8, 2025 | 08:57 PM
85e150's Avatar
85e150
It might be a Holley 2300 series. Look at the choke horn, front side for numbers stamped into it. Looking for the "List" number.
It could also be an Autolite or Motorcraft 2100.
You can post a pic if you like.
I'll get back to you on the rest of the decode.
Old Feb 9, 2025 | 01:31 AM
85e150's Avatar
85e150
Good luck with it!
Old Feb 9, 2025 | 08:27 AM
FormalDragon
This is the tag on carb.
Old Feb 9, 2025 | 09:53 AM
85e150's Avatar
85e150
These vary a little by application. That might be the original carb. Yours has the manual choke linkage.
https://www.carburetion.com/CarbNumb...vJXxU1zxdYo4y3
Rebuild kit:
https://www.carburetion.com/products...?part=KT-5142B
Old Feb 9, 2025 | 06:56 PM
Destroked 450's Avatar
Destroked 450
330 MD used a Autolite carburetor, the one in the photo is a Autolite
Irishmick63
Large Truck
May 8, 2023 11:38 PM
xgkrx
20
Jul 10, 2022 05:04 PM
