Sponsored by: Real Truck
Lube Locker for D50
Old Feb 6, 2025 | 10:08 PM
StngStr's Avatar
StngStr
Lube Locker for D50
Does the D50 front in my 99 F250 take the same Lube Locker gasket as the 10.5 rear?
Lube Locker website doesn't list the D50 as an option.
Old Feb 7, 2025 | 12:49 AM
Boaterguy's Avatar
Boaterguy
No it is not the same. However, the Dana 50 and D60 use the same gasket I believe. Might want to contact Lube Locker to verify.
Old Feb 7, 2025 | 09:03 AM
Antonm23's Avatar
Antonm23
The rear is (or at least should be) a Sterling axle, so no, not the same as the Dana front.
Good news (sorta) is the solid dana 50 axle is basically an Dana 60 housing with a Dana 44 sized gear set in it, so the cover gasket for a dana 60 works on the Dana 50.
Old Feb 7, 2025 | 10:00 PM
StngStr's Avatar
StngStr
Ok...so Dana 60 gasket for the front, 10.5 gasket for the rear.....got it.
Thanks!
Jackie Barnes
Jul 26, 2020 05:22 PM
86caprirs
Apr 19, 2008 04:26 PM
joeypurcell
May 4, 2004 08:31 PM
99f350sd
Offroad & 4x4
May 26, 2003 08:07 PM
