Hello...I have a 1992 e-150 conversion van. I just got back from a camping trip and all of a sudden my turn signals do not work...I checked the fuses both in the van and the ones inside the engine compartment and they appear to be good but i cant figure out why they dont work...does anyone have any ideas...i appreciate any info
Thanks
Mike
Originally posted by sidala where is it...there is an empty spot in the fuse box but there is nothing in it and never was so is it somewhere else?
Thanks
You probably have 2 flashers, one for turn signals, the other for the 4-ways. Turn on the 4-ways, find it's flasher by the sound. You don't want that one. Your other flasher can be anywhere. If it was working, evidently the flasher wasn't removed from the fuse panel.
They sometimes go out of their way to hide these dang things, so you'll have to look all around up under the dash.
My old '86 was located on top of the steering column bracket, and I had to remove the whole dash to get to it.
Out of interest, has your heater blower motor quit too?
If you have no heater blower & no turn signals, try gently moving the ignition key backwards & forward slightly. Not as far forward as to engage the starter, or back to cut it off.
sidala....when you find out could you let me know!!!? I have the same problem and I've had auto parts people under the dash and we cant find it at all. Last night an Auto Zone cashier said it MAY be on the firewall. Will look today......
...Welcome Bmoutray, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
