302 long pilot bushing question
Old Feb 3, 2025 | 11:46 AM
dparcell's Avatar
dparcell
7th Gear
I am installing a 302 in a 1971 F-100 in place of the original 360. I am told that the small block bell housing is longer than the 360 bell housing and therefore I need a longer pilot bushing (3/4 inch longer) to make it work. Anyone know where I can source a longer pilot bushing?
Thanks,
Dave
Old Feb 3, 2025 | 12:29 PM
52 Merc's Avatar
52 Merc
I can't speak to the bellhousing, but the real difference is the length of the pilot shaft on the end of the transmission input shaft. The transmissions for small block engines have a longer pilot snout than big block transmissions. The quick fix for that is the extra long pilot bushing since a big block trans won't fit into the standard bushed small block crank. The correct fix is to use a small block transmission. I haven't seen an extended bushing for a long time, but I haven't looked for one, either. Keep us posted on what you find, please.
Ford toploader | StangNet
Old Feb 3, 2025 | 01:10 PM
davelj's Avatar
davelj
Dorman used to make the extra deep pilot bushing but I have not seen them for years, either.
Old Feb 3, 2025 | 11:18 PM
RichS2659's Avatar
RichS2659
There is a difference between the depths of car and truck bell housings. Truck main shafts have the same length between T-18/NP 435. Car transmission mainshafts are shorter compared with truck mainshafts. Here is a chart:
https://www.davidkeetoploaders.com/bellhousingidchart.htm
T-18/NP 435's have a 6 1/2 stickout as per Novak Conversions.
You need a truck 302/351W bell housing. And the photo above is for T&C Top Loaders, not truck T-18/435's.
Since this is 4wd drive, you will need 77-79 351M/400 4wd engine supports to convert to a 302 also.
Old Feb 4, 2025 | 10:39 AM
dparcell's Avatar
dparcell
7th Gear
The casting number on my bellhousing is: D9TA 7505-CB which does not show up on the charts. The depth measures 6-3/4 which suggests the input shaft will be about 1/4 short. Sounds like I am back to trying to find a long pilot bushing?
Old Feb 4, 2025 | 10:49 AM
dparcell's Avatar
dparcell
7th Gear
Per the response above, I checked with Dorman and they don't have the part any longer.
Old Feb 4, 2025 | 01:17 PM
RichS2659's Avatar
RichS2659
Those charts are for car Top Loader bell housings. What is important is the fine print at the bottom of the charts. Truck bell housings = 6 3/4". That is what you got. The T stands for truck usually.
Old Feb 4, 2025 | 02:47 PM
dparcell's Avatar
dparcell
7th Gear
Thanks for your responses. Assuming the bell housing I have will fit (which the ebay listing you provided indicates it will) do I need a long bearing if the input shaft is 6-1/2 and the bell housing is 6-3/4 deep?
Old Feb 4, 2025 | 05:59 PM
davelj's Avatar
davelj
I would mock it up. Install the bellhousing and a pilot bushing with no flywheel or clutch. You should be able to see through the clutch arm hole if the input is supported.
That said, i did find a pilot that is .900 inch wide. It might be an option but would need to be cut down.
https://www.moderndriveline.com/shop/sb-ford-pilot-bushing-extended-670-id-x-900-long/
Corrected post.
Old Feb 4, 2025 | 11:23 PM
RichS2659's Avatar
RichS2659
Advance Adapters kit to convert an EB to a T-18/NP 435 uses the stock Bronco pilot bushing/bearing so it seems the stock 302 one is OK. I think the extended one is for use with the taller truck bell housing and a car Top Loader trans which has a shorter mainshaft. Modern Drivelines deals with car transmissions mostly compared with 4wd and truck shops.
Old Feb 5, 2025 | 11:48 AM
dparcell's Avatar
dparcell
7th Gear
Lots of good information, thanks everyone. I just spoke with Modern Drivelines and they have an 1" extended bushing but wanted me to confirm the input shaft diameter is .670. Can anyone confirm that?
Old Feb 6, 2025 | 07:22 AM
fe390pc's Avatar
fe390pc
I think I would do the test fit as suggested to verify if it will work with what you have. I did install a FE style 4sp into my F100 small block years ago with no issues.
Old Feb 6, 2025 | 09:44 AM
dparcell's Avatar
dparcell
7th Gear
Thanks. I think the test fit is the safest route to go. Two things, I spoke with Dan Williams, a transmission guy in NC who I was told knew all about this issue. He said the best thing to do is the change the input shaft, but he thinks Ford does have the extended bushing. I tried to find it but was unsuccessful. I did find however, a 1" think bushing (compared to 1/2" stock) through Modern Drivelines. (Pilot bushing, Pontiac, Ford SB, Extended 1.380"od x 670"id x .900" wide, MD-404-1018) The cost was a bit high at $60 but if it solves the problem, it will be worth it. Will let you know how it all turns out. Hoping to get the small block install started next week.
Mark68F100
Aug 11, 2022 05:53 PM
ManfredVonRichtofen
WTB - Parts & other
Nov 13, 2013 02:50 PM
57 ford ugly
Apr 17, 2010 12:48 AM
daveengelson
Jun 2, 2006 05:28 PM
andyz
Nov 29, 2002 09:22 AM
