I would check the piston to valve clearance either way
That head gasket should work
I would "clay" the motor myself (use modeling clay)
You can always buy a special valve spring or remove the outer spring on one of yours sometimes and use your original valve spring to check piston to valve clearance
Watch a few videos about that
That will be a fun build for you
The roller cam will be nice
