E4OD shifting back and forth
Old Jan 28, 2025 | 11:14 PM
JSontchi's Avatar
JSontchi
Trailering
When up to speed the transmission shifts back and forth. Also while accelerating it seems the torque converter isn't engaging all the way. I've just replaced the tps and mlps and I disconnected the battery to do the tps so the codes should have wiped. I don't have any active codes just two stored which are 212, 332, 637 and this is from the KOEO test. Could this be caused by the 637 code or is there something else going on?
Old Jan 29, 2025 | 09:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Please explain what it is doing when it shifts back and forth.
Old Jan 29, 2025 | 10:44 AM
JSontchi's Avatar
JSontchi
Trailering
when I get up to about 45 to 50 it starts shifting back and forth pretty quick jumping from 1400 to 2000 rpm. if I give it enough gas it stays at 2k and if I let off it drops to 1400 and stays. so it only does it when I'm cruising and giving it 20% throttle or so.
Old Jan 29, 2025 | 05:33 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
212 (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault – Ignition Systems
What engine do you have? Maybe the guys know how to test your tach sensor.
Old Jan 29, 2025 | 07:12 PM
JSontchi's Avatar
JSontchi
Trailering
This is going to sound crazy but it's a 5.8 out of a 96 f250. The original motor was a 5.0 and as far as I can tell they left the fuel and air system from the 5.0 as well as the original PCM. Now the original PCM quit working so the PCM right now is out of a 93 E-350 with 5.8 and e4od. If I had to assume it's the original tach for the 5.0 but I may be wrong
Old Jan 30, 2025 | 01:57 PM
wwhite's Avatar
wwhite
What EEC is in the truck now? picture please.
What year and type of trans is in the truck now? E4OD or? 1996 or?
Do you have LED brake lights?
junkyardjeff
Feb 3, 2025 07:17 PM
countyboy22
21
Aug 26, 2012 04:20 PM
rangergirl94
19
Feb 24, 2012 11:55 PM
kiohio1985
Aug 30, 2006 08:20 AM
JCATC
Apr 8, 2004 07:15 AM
