2012 FX4 3.5
Old Jan 28, 2025 | 10:05 AM
joshc15's Avatar
joshc15
5th Gear
2012 FX4 3.5
Windows, all 4, not working. Replaced the driver door harness. No luck. Window switch? Anybody else have this problem?
Old Jan 28, 2025 | 10:10 PM
steve(ill)'s Avatar
steve(ill)
did you check the fuses and breaker ? POWER to the switch ?
Old Jan 29, 2025 | 08:58 AM
joshc15's Avatar
joshc15
5th Gear
Yes I checked the 3 fuses in the passenger foot rest area. Seemed good.
Old Jan 29, 2025 | 03:25 PM
BC2019F250's Avatar
BC2019F250
I would check the wire harness that goes into the door to make sure all the wires are good.
Old Jan 31, 2025 | 06:10 AM
joshc15's Avatar
joshc15
5th Gear
First thing I checked was fuses. Then moved on to the wiring harness. Replaced. Neither fixed. Then I bought a new switch. No help. Ended up being the relay in the fuse box!
1Archer
16
Mar 30, 2023 06:22 AM
Tim Hodgson
Electrical Systems/Wiring
Nov 16, 2017 08:22 PM
wookinpahnub
Jan 7, 2011 10:45 AM
drew213F250SD
Aug 31, 2010 08:17 PM
BIG-FUJIMO
Sep 24, 2007 02:55 PM
