I have a Crew Cab and on the buttons on my drivers door you can roll the rt passenger and the back rt passenger with just the back rt passenger button and you can roll them both up seperatly but if you try to just roll down the rt passenger window with the driver controls and hold it eventually it will start to smell like electrical smoke and it won't roll down but it will go up if it is already down from rolling the rt back window down. WTF? has anyone else had this problem? Hope I didn't confuse anyone its hard to explain by typing.
I Had Kinda The Same Problem With My Rear Pass. Window It Would Work Itself But I Couldn't Do Anything From The Driver's Switch. Took Everything Apart Ended Up The Rubber Boot on The Rear Pass. Door That Goes From Door To Body, Pulled It Back And A Couple Of Wire's Had Got Cut Over Time solder Them Back Together And BAAMMM It Works Don't Know If That It, But Good Place To Start
I have never heard of anyone having this problem. If I understand corectly if you try to put the rear passenger door down from the drivers door switch it puts down both passenger windows? If so there is definitely something wrong with the switch or the wiring.
Yeap thats right I Just didn't want to go replacing parts if someone else already figured it out I'll probably swap the switch out of my dads CC and try it with his.
