GMRS mounting options
Old Mar 3, 2025 | 03:51 PM
Fallon's Avatar
Fallon
Originally Posted by Joz
I installed the head unit of my Yeasu Ham radio in the compartment under the radio on my '23 Super Duty. It interferes with the sliding cover but I don't care as I don't use it anyway.
Regarding the antenna mount, I used a fender mount which seems to work well enough.
Nice setup. Just realized you are nearby as well. Mind if I pick you brain on some flatbed stuff?
I'm holding off on mounting up my radio gear until I get the flatbed here in a few weeks. Did you put the flatbed on, or have an upfitter do it? I got the flatbed included with the truck to make sure the dealer is on the hook for any configuration stuff the upfitter can't do or I can't do with Forscan. The dealer has Maxey Truck Fitting up in Ft Collins doing it. I'm just hoping they don't butcher the wiring & its not a pain to fill up the fuel or DEF tanks. I'm expecting to have to fiddle with cameras & some config stuff a bit. I know BLIS is toast & obviously anything the tailgate.
Mounting the antenna is my primary blocker. I'm a little restricted if I want to be able to park it in the garage. The headache rack is likely to not fit as it is. No sun roof, so a NMO in the center would work, but I'm loathe to drill a hole in the brand new truck. I probably have room for a https://bulletproofdiesel.com/collec...-duty-90201129, but it's spendy. The headache rack will be a worse ground plane than the NMO in the roof. None of those options will permit any kind of antenna, but just a cap on the NMO for the roof or brake light should fit. The hood is always a place, but sacrifices convenience for coverage due to a lopsided ground plane & the cab blocking stuff.
Old Mar 3, 2025 | 03:58 PM
Joz's Avatar
Joz
Hey Devin. Wow! That's a close fit.
I had an upfitter install my bed. I'll direct message you with photos and comments to not clutter up this thread.
-Mark
Old Mar 23, 2025 | 03:24 PM
Fallon's Avatar
Fallon
Originally Posted by tbwill
There is a Ham Radio Install thread in the 2017-2022 Super Duty sub-forum. Some of the posters have mounted their external displays in the overhead sunglasses holder.
https://www.ford-trucks.com/forums/1...o-install.html
Old Mar 24, 2025 | 07:33 PM
wabba's Avatar
wabba
I just posted a write-up on my radio install and how it was done, FWIW. Was following this thread as well trying to decide what to do.
GMRS radio install, wiring and mic bracket. - Ford Truck Enthusiasts Forums
ZR1PETE
Jan 3, 2019 05:28 PM
webrx
Jun 13, 2009 07:21 AM
bogelthorp
May 21, 2007 01:09 AM
97F250XLT
Mar 5, 2007 10:29 PM
