Check Engine Light Not working
Old Jan 25, 2025 | 04:23 PM
Sumano's Avatar
Sumano
1st Gear
Hi,
I have a Ford 2008 E350 and the check engine light is not working (it won't turn on at all, not even when starting the van) . Any one know how to troubleshoot the issue? All other lights in the cluster work, except for the check engine light.
From a previous post on here https://www.ford-trucks.com/forums/1...ight-wire.html
The PCM can be programmed to disable the MIL/check engine light? Anyone know how to enable it back?
I tried swapping a different PCM that I bought used from Ebay (VIN was programmed by seller) however Van won't start or crack. Probably got a bad PCM or VIN number was not programmed correctly?
Anyway to test the check engine light on the cluster through the connector pins?
Thanks,
Gabe
Old Jan 25, 2025 | 05:44 PM
etinpa's Avatar
etinpa
No...
The schematics do not show any external connection to the CEL.
As mentioned in the referenced post, I also imagine the PCM signals the IC to turn on the CEL via a network connection (likely the CAN bus as the IC has a connection to both the MS CAN bus and the CAN but the PCM only connects to the CAN bus). I don't know if the original "prove out" of the CEL is initiated in the IC or the PCM.
Vendors seem to list a replacement CEL bulb up to 2007 but not after so I'm guessing the CEL is not a normal replaceable bulb.
Old Jan 26, 2025 | 05:07 AM
manicmechanic007's Avatar
manicmechanic007
The pinpoint tests for the instrument cluster will walk you through the bulb diagnosis
Cracked solder joints in the cluster come to mind
Yes, there is a way to check the cluster bulb (LED) circuit
A 08 service manual is what you need or AllData
Cluster diagnosis and a no check engine lamp flow chart is what you need
Gwilkrrs
Jan 21, 2022 08:26 AM
96SD
Nov 22, 2019 09:21 AM
stang32
2004 - 2008 F150
23
Apr 1, 2019 08:13 PM
oric
Nov 15, 2003 03:38 PM
