Sponsored by: Real Truck
Check engine light wire
Old Dec 1, 2021 | 09:30 PM
roboford's Avatar
roboford
I purchased a used truck but the check engine light never come on even it has emission related codes such as 0420, 0430. I suspect the previous owner removed the wire from the computer to trigger the CEL. I check the wire diagram but couldn't find out where the CEL light was. Can anyone tell me which wire or connector pin that trigger the CEL on.
I want to enable the CEL back on since sometimes there is something wrong the truck but I don't even realize it.
Old Dec 2, 2021 | 07:34 AM
bajaphile's Avatar
bajaphile
What year truck is it? I have a 2001 Wiring Diagram I can look through, still learning how to use it...
From what I've seen in the past, most people will remove the bulb, or the bulb burns out. Haven't seen anyone cut a wire (yet)...Might be easier to simply remove the dash and check the bulb. At that point you'd probably find the possible cut wire.
Old Dec 2, 2021 | 12:25 PM
roboford's Avatar
roboford
Mine is 2008. The light is on for a short period of time when I turn on the key so I am pretty sure the bulb is still there. I have the wire diagram as below link but I cannot find MIL light anywhere.
2008 F-250 wire diagram - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Dec 2, 2021 | 12:32 PM
ifrythings's Avatar
ifrythings
There is no MIL wire, the MIL light is turned on over the HS CAN bus, if all the gauges work and the MIL won’t turn on after prove out then someone’s been messing with the pcm program.
Old Dec 2, 2021 | 04:43 PM
Djosbun's Avatar
Djosbun
If the computer triggers a DTC, the light would come on since you have stated the light illuminates when you turn the key to the on position. Are you certain that those trouble codes are current codes and not historical codes? I'm assuming you're using a scan tool to read these codes?
-- Dave
Old Dec 3, 2021 | 12:39 AM
roboford's Avatar
roboford
Hi ifrythings, I assume the instrument cluster IC receives the signal from PCM through HS CAN bus, decode it and turn on associated lights in the cluster, correct? If so, in order for the MIL light to be on, it needs a power through the light. Where is this light in the diagram? Are the three diodes in message center module switch (pin1) the light for MIL?
Old Dec 3, 2021 | 12:44 AM
roboford's Avatar
roboford
-- Dave
Yes they are all current code. I also had code of misfire due to broken connectors on fuel injectors and coils but MIL was never shown up.
Old Dec 3, 2021 | 08:24 AM
ifrythings's Avatar
ifrythings
The PCM sends several CAN packets that the IC uses and other module’s also, if your tach and speedo are working properly then the PCM and IC are talking correctly. You stated that when you turn on the truck the MIL turns on for a few seconds then turns off right? So it proves out and it works, the MIL is not shown on the diagram as it’s integrated into the IC, the power for it would also be the main power for the cluster pin 1, the message center switches show the 3 LEDs for the back light for the switch.
From the sounds of it, the MIL proves out then turns off, that means the light is good and the PCM is telling the IC to turn the MIL off, if the PCM wasn’t talking to the IC the MIL by default stays on until the IC gets the message from the PCM to turn it off. To me it sounds like the PCM has had something done to it to keep the MIL off.
Old Dec 3, 2021 | 10:01 AM
roboford's Avatar
roboford
thanks! It makes sense. My tach and Speedo are working property. It sounds like someone programmed the pcm to disable the mil light. Here is the light of my cluster immediate after key is on
robdog6942
Apr 18, 2020 09:16 PM
jiggerk
Aug 29, 2019 11:43 PM
Mostlyford
Bronco II
Feb 28, 2018 01:51 PM
murphydo
Jun 19, 2001 07:43 PM
Pastmaster
Dec 2, 2000 09:48 PM
