Glow plugs?
Old Dec 2, 2003 | 10:54 PM
Dirtracer14's Avatar
Dirtracer14
Glow plugs?
Now that its cold out my truck is really hard to start first time for the day. If i plug it in it will fire right up if i dont plug it in it could take upto 10 min in 30 deg weather. I replaced my bats thinking maybe they were a tad weak but didnt help. This is a 99 F350 7.3 with 112,000 miles with no problems since i have owned it at 56,000. I get reg oil changed and filter change but never done the glow plug relay or glow plugs... or the high oil level not sure what that is but read people talking about it. If someone could help with this that would be great. I have not really looked at the motor much but i looked for the glow plugs this weekend with no luck. (they under the valve cover?) I am no dummie when it comes to cars and motors(I race a dirt mod) but not to much on the 7.3 and would like to do the glow plugs myself. Thanks Craig Moore
Old Dec 3, 2003 | 12:46 AM
kevinrf250's Avatar
kevinrf250
The glow plugs are under the valve covers, They are right next to the injectors toward the center of the engine, they have one wire going to them with a black cap. they are very easy to replace if you have any mechanical skill.
Old Dec 3, 2003 | 02:21 AM
Quadzilla's Avatar
Quadzilla
In replacing the glow plugs, you'll find that getting the valve covers off is the most troublesome part of the whole job. While you're in there, replace all eight glow plugs, and inspect the wiring harnesses that are inside the valve covers closely. The plastic pieces can get brittle over time, and a faulty connection can give you problems.
Old Dec 3, 2003 | 08:25 PM
Dirtracer14
Ok now how do i know if the plugs are bad or if its a relay? What about the high oil thingy? I mean i dont want to have to tear into it if its just a relay. Thanks guys
Old Dec 4, 2003 | 01:20 AM
woody_f250's Avatar
woody_f250
How many hours would it take to replace my glow plugs? I've narrowed it down and that is one of the few things left to check. Can you check them without removing anything? Or do I have to tear into it to see if they are bad? I'm taking it to a shop this morning, will their machine be able to tell if it's the glow plugs?
Old Dec 4, 2003 | 01:14 PM
woody_f250's Avatar
woody_f250
Nevermind! It just needed a good charge on the batteries.
Old Dec 4, 2003 | 02:40 PM
kevinrf250's Avatar
kevinrf250
To test the glow plugs you have to pull them out and check their resistance. If you have gone through the truouble to get them out it is worth it to replace all of them then you are sure that they are good. Don't know how to tell if it is the relay. never ran across that problem.
Old Dec 4, 2003 | 07:09 PM
JRM99's Avatar
JRM99
If you had a bad relay I think you would have charging problems. The relay gets quite a bit of power and if that was fried you would know.
Old Dec 5, 2003 | 11:43 PM
Dirtracer14
Where is the relay?
Texasthb
Jul 24, 2015 12:09 PM
catbird7
Nov 16, 2011 04:41 PM
david moore
Sep 10, 2011 12:33 PM
mcphm519
Jan 9, 2011 08:54 PM
northernlights
Nov 20, 2009 09:52 PM
