Just order a new pipe and possibly a new one way valve to go with it
Google ford 351 thermactor air pipe between the heads
The parts stores should have them by now too
Might need a torch to heat up the threads and remove the one way valve
That will ruin the valve in some cases
At the dealer, I replaced both to prevent a recheck
For 70 bucks, I would consider finding a good one at the junkyard for 10 or 20 and get the whole thing with the valve
Course I have 2 good junkyards close and 5 within 40 miles
On a car once, I used J B Weld as a sealant and used a piece of thin stainless steel scrap, clamped in place with stainless steel zip ties and snipped ends.
351C/351M/400 series 335 engines and the old Boss 302 have 8 bolts holding each valve cover on
429/460 series 385 engines have 7
221/260/289/302/351W small blocks have 6
332/352/360/361/390/391/406/410/427/428 FEs have 5
and 239/256/272/292/312 Y blocks use but 2.
