Slow Windsheild Wipers
Old Jan 23, 2025 | 09:15 PM
seventyseven250's Avatar
seventyseven250
I assume this is a weak wiper motor, but it's always worth getting a second opinion from the forums. Anyone know why my widnsheild wipers seem to move slowly across the window, both up and down, dry or wet? Not uniformly slow every day, but clearly slower than new. Don't think it's voltage related, as I do have a voltage readout thingy and it does it even when voltage is 14.8.
Sugestions?
Old Jan 24, 2025 | 10:14 AM
GlueGuy's Avatar
GlueGuy
I'm not certain, but if you can lift both wipers to the up-and-locked position, you could run them to verify it's not some kind of friction thing. Otherwise, I suspect you have a bad wiper motor. Second guess is the regulator. Not sure where that is.
Old Jan 24, 2025 | 01:09 PM
SpencerPJ's Avatar
SpencerPJ
My thought too, I have replaced wiper blades on my truck, some glide easier than others for sure. OP, have you changed blades recently?
Old Feb 3, 2025 | 12:02 PM
seventyseven250
I didi this test and yeah the arms move same speed on and off the window, so I'm pretty sure it's the wiper motor. How hard is that swap?
Old Feb 3, 2025 | 01:00 PM
GlueGuy's Avatar
GlueGuy
This is a bit older truck, but it sure looked pretty easy to me.
Old Feb 11, 2025 | 07:07 PM
snomo23's Avatar
snomo23
3rd Gear
I recently had this issue with my 2017 F-150 it ended up to be my wiper transmission not the motor the wiper transmission joints are prone to rust an seize up replacement was about $70 from auto zone
Dorman Wiper Transmission 602-182
Old Mar 20, 2026 | 05:57 PM
seventyseven250
I went ahead and replaced the wiper motor AND linkage (aka transmission) and it wasn't a terrible job. It's possible that just the linkage would have done it, but I didn't want everything apart without parts in hand. I'm slow at everythingk but this only took me 2.5h. Probably 80% of that was taking apart the cowl to access things. Issue solved.
Note the linkage has different versions. On my 2020 the current is JL3Z 17566 F. A-b-c-d-e are all superceded. Bought the parts from the dealer, they seem to be hard to find around here.
6.9_4spd
Feb 17, 2024 08:14 PM
jerryst
Jun 14, 2021 01:12 PM
fordman49
1997 - 2003 F150
Dec 14, 2009 10:54 PM
Vien
13
Jun 14, 2005 01:14 PM
allanlepage
1983 - 2012 Ranger & B-Series
Nov 10, 2004 08:27 AM
