Windshield wipers not working.
Old Sep 13, 2023 | 05:16 PM
6.9_4spd's Avatar
6.9_4spd
I have a 1985 ford f250 6.9 diesel and my windshield wipers don’t work. I don’t have anything, no noises, nothing, totally dead. Does anyone know why this is? Is it a common problem? I got the truck a couple months ago and I didn’t have wipers then either. It was sitting for two years when I got it.
Here is a Video for you to watch.
Old Sep 14, 2023 | 09:56 AM
tecgod13's Avatar
tecgod13
Check for voltage at the wiper switch, if you get voltage there, have the wipers on and check for voltage at the wiper motor.
Old Sep 14, 2023 | 03:20 PM
tjc transport's Avatar
tjc transport
i ain't rite
does the switch turn counterclockwise? if it does, that there is delay wipers.
the delay module tends to go bad and you will loose wipers.
Old Sep 14, 2023 | 07:40 PM
6.9_4spd's Avatar
6.9_4spd
On is clockwise off is counter clockwise.
Old Sep 14, 2023 | 07:41 PM
6.9_4spd's Avatar
6.9_4spd
ok I will try that unless I get a better suggestion.
Old Sep 15, 2023 | 06:27 AM
tjc transport
i ain't rite
sorry, should have been more specific.
clockwise you have low, than high setting. three separate settings on the switch.
if it turns counter clockwise from off setting that is delay wipers.
Old Sep 15, 2023 | 02:32 PM
6.9_4spd's Avatar
6.9_4spd
Yah it goes clockwise from off.
Old Sep 15, 2023 | 05:46 PM
tjc transport
i ain't rite
ok, than you have delay wipers. feel along the wire from switch up towards firewall and wiper motor wires. you should feel/see a small box, around 2 1/2 inch square. it very well may have been removed because it was bad and never replaced.
this one is from an 87, so it may be a little different than your, but they all pretty much are the same size.
on mine the switch plug is different than the motor side plug. but i believe the pre 87 units had the same plug both sides. just don't remember for sure..
Old Feb 17, 2024 | 08:14 PM
6.9_4spd's Avatar
6.9_4spd
Again thanks. It ended up being the motor.
zoomeroo
Jan 12, 2022 12:49 PM
My1964ford
Jun 7, 2017 12:07 PM
wwwjames
2004 - 2008 F150
Sep 8, 2004 08:05 PM
dawid311
Aerostar
Mar 26, 2004 10:34 PM
