Complete battery cable replacement
As Abraham Lincoln once said.... don't believe everything you read on the Internet.
Performance Custom Cables
https://www.performancecustomcables.com/
there won't be any corrosion.
just to make sure, I coat the terminals with Fluid Film, this pix is for batteries I bought 30 months ago
I've tinkered around with battery cables since 1977, and am still learning new nuances on the topic, that continuously evolves with advancements in materials.
Kinda like having my transmission built by BTS, and wondering when to change the fluid
Should I call Brian, the guy who built it and has to warranty it, or listen to a guy on the Internet who knows a guy.
These wire / cable manufacturers, make it and certify it for particular applications, they have to stand behind their products.
2-O battery cable is over 5,000 copper strands in it.
and a properly crimped terminal will make those strands like a single strand, squeezed so tight, it is impossible to corrode, if the outside is properly treated.
Shrink Wrap and a coating:
for me, Fluid Film / Woolwax, other lanolin based products.
And let's stop dismissing each other as "some guy on the internet."
We are all here to help. We are all here to learn. We are all here to see perspectives outside of our own experience. And we are all here to share our own experience.
How do we manage to do all this?
By being on the internet. Obviously, we are all on the internet.
Tin cans and string have limited reach.
In pot meet kettle irony, how can I dismiss someone for being on the internet... when I encountered them by being on the internet myself?
Rather than find fault with the messenger, or the means by which the message was conveyed, let's find fault with any fallacies, and focus on finding facts.
Ford ran out of OEM battery cables, and the aftermarket is a swamp that can mislead when only looking at the surface. Alligators and undercurrents exist below the surface, so it is good to take a deeper dive beneath the surface once in a while to share tips and best practices when choosing between battery cable offerings and solutions in the aftermarket.
That is what this thread is about.
So let's see that math!
In this discussion, wire is simply a conduit to transmit electricity. When we start throwing out terms like welding wire, battery cable etc..that really makes it confusing, because these classes of wire service many other applications.
There are basically three classes of wire for automotive battery cables that I know of
First is the Walmart/ AutoZone type cable very few, thick strands of copper. These are good to 60 v, amperage is based on cable size
The second is Class k, which has a lot more thinner strands, good to 600v, commonly called welding cable
The third is Class M, with even smaller and more copper strands, good to 1000v, called diesel and locomotive cable.
I use Class K, very flexible, good oil heat resistance and resistant to cutting, scuffing. Good mid-range between Walmart and Class M
Each of these Classes have industry standards as to strand size and number of strands per wire gage which can be easily located on mfg sites.
Rather than find fault with the messenger, or means by which the message was conveyed, let's find fault with any fallacies, and focus on finding facts.
I agree with you and others on the "welding cable". It costs more, but brings the advantages of better flexability for routing and IIRC increased current carrying capacity. That first one is generally enough of a reason for me to use it. Seems like welding cable is also usually a better quality of material than wire typically marketed as battery cable.
Is there some truth to the corrosion angle that @Pikachu mentions, possibly. For corrosion to be an issue it has to be exposed to a corrosive environment. If the welding cable is properly cleaned before terminating, properly terminated, and properly protected at the terminals, there is no exposure to that corrosive environment. If you aren't going to do those things, then it isn't going to matter what type of cable you use, it's going to have corrosion issues.
I'd join your "Lets see the math!" chant, but I wouldn't know what to do with the math if I saw it. Or if I did know what do do with it, I couldn't be bothered to do it. Math is great, but it doesn't always hold up once exposed to real world variables that it doesn't account for. In these situations I'd rather go with the real world tested results, which say that welding cable makes for great (but expensive) battery cables.
I don't oppose the use of certain types of welding cable as battery cables in a vehicle... but it would depend on the type of welding cable, and I wouldn't be inclined to seek that solution.
And I have a 200 feet of unused heavy gauge welding cable coiled up around here that has probably trebled in value since I bought the spool many years ago.
There are a lot of factors to consider, and I'm interested in reading what other's have to say about it.
I did purchase and am using welding cable as battery cables for a special project. I've got a 5k winch for use with my flatbed trailer or anything else I may need a similarly sized winch for. It is mounted on a reciever hitch for versatility, and as such there is no vehicles to mount control box onto. The couple of times I've used it in the past was sans control pack, with a battery hooked directly to posts via jumper cables. It works, but not the greatest idea. I've got a plastic "ammo can" purchased for the purpose of building a control box for the winch, but regular battery cable is too stiff to make a neat install with the needed bends. Welding cable is going to do the job great.
