I found this on a search
Under the hood, right at the front where the air goes into the airbox. See if that is open. I've seen them where the clips holding the duct in place are missing and it sucks the rubber into the tube.
Also as pointed to here, is the air filter good?
Another one talked about a PCV hose off that was leaking all the boost?
