Constant Trailer connected/disconnected alerts
Old Jan 24, 2025 | 06:59 AM
rabidranger's Avatar
rabidranger
A few minutes after my truck (2018 SCAB Raptor) is warmed up and I accelerate from a stop I get a "Trailer Connected" Alert on the dash. When I brake I get the "Trailer Disconnected" alert. Back and forth. Da-ding, da-ding, da-ding. Makes me want to jerk the wheel into oncoming traffic. Seems worse when the temp is above freezing. Sometimes a "Trailer right turn lamps fault, check lamps" alert pops up. Same alert for left lamps too, usually one after the other. Sometimes the trailer blind spot fault pops up too, but I forget the actual alert phrasing. I checked the plug in the bumper and even cleaned it out with some good contact cleaner. Still does it. Unplugged the harness from the bumper connector and taped it off. Still does it. Those 2 connections look good and brand new, no signs of corrosion. Not sure where to check next. I know there is a TSB for this, but dealer wants $200 to diagnose and my truck is out of warranty. Any advice?
Old Jan 24, 2025 | 07:48 AM
SpencerPJ's Avatar
SpencerPJ
I would start with laying underneath rear of truck, unplug every connection visible, inspect, spray with wd40 contact cleaner, reassemble.
Old Jan 24, 2025 | 10:13 AM
scott91370's Avatar
scott91370
From what I remember in posts this is almost always a ground issue.
Old Jan 24, 2025 | 01:11 PM
SpencerPJ's Avatar
SpencerPJ
This thread mih have some useful wiring info https://www.f150forum.com/f118/blis-...-issue-562815/
Old Jan 25, 2025 | 10:57 AM
JKBrad's Avatar
JKBrad
Sometimes it's corrosion on the plug itself. If you look in there and see any corrosion, spray some gun barrel cleaner or WD40 in there and use a bore brush to clean around the inside of the plug.
Hockey18
Jan 17, 2026 03:50 PM
Edd505
Dec 22, 2025 09:15 AM
IDI Diesel
Oct 26, 2024 08:05 AM
Frank79
Apr 21, 2020 11:21 AM
bluejayman
2015 - 2020 F150
Nov 16, 2018 06:13 PM
